1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
V10 Gas vs Diesel "The Truth"
Old 04-27-2015, 12:51 PM
Pocket's Avatar
Pocket
Pocket is offline
Originally Posted by Fishin76
wow, i NEED to look at dates... erased my response... sorry folks..
One last thing....
Torque is how much work can be done.
Horsepower is how fast it can be done.
Thats all there is to it.. period.
Not really.
Torque is an instantaneous measure of force at a given moment.
Horsepower is the measure of work being done over a period of time.
Once those concepts are understood, then it's easy to sort through what is fact and what is BS in this thread.
  #137
Old 04-27-2015, 12:58 PM
Diamnd1's Avatar
Diamnd1
Diamnd1 is offline
Torque= size of fist.
HP= how fast fist moves.
  #138
Old 04-27-2015, 05:16 PM
scraprat's Avatar
scraprat
scraprat is online now
Received 2,528 Likes on 1,320 Posts
Groundhog Day
Groundhog Day
Groundhog Day
Groundhog Day
Groundhog Day
Groundhog Day
  #139
Old 05-02-2015, 05:35 PM
Realslowww's Avatar
Realslowww
Realslowww is offline
One last thing....
No this post is good, I had another thread going and Pocket says HP is HP then people would post and say no it isn't my Diesel pulled way better than my gas engines and he would battle back and say yes it is.
What you say is what I have been told and you can only gear around lack of torque to do a job to a degree.
The V 10 is a great engine but does not have the torque of a good diesel, you could not give one of the new diesels however, to complex and expensive.
Even engine builders some of them do not understand what torque HP #'s mean in the real world, It is my belief a 500 HP Semi engine is way way way more powerful than a 500 HP engine that spins at 7 or 8 thousand RPM and has way more ability to build and maintain HP ( MPH ) under a big load.
If I am wrong I am wrong however. By the way I read somewhere Pocket got a new truck hopefully it has the torque to do the jobs he asks of it.
  #140
Old 05-02-2015, 05:40 PM
Realslowww's Avatar
Realslowww
Can a bunch of fly weight punches do the job of a big fist that punches less ?
  #141
Old 05-02-2015, 05:58 PM
Realslowww's Avatar
Realslowww
Originally Posted by Pocket
Not really.
I did not realize you were back, please explain this if you would not mind.
This is kinda what got me thinking about this a long time ago. I have 2 motorcycles, each one makes 55 RWHP on a dyno at the rear wheel. One makes the 55 at 5500 RPM and the other 55 RWHP at 8500.
Both machines geared correctly will go max 100 MPH exactly the same speed within a MPH all things being equal but if you have both machines geared to go exactly 50 MPH redlined in 3rd and you pull the clutch in going like 3 MPH and rev both bikes to the moon and drop the clutch why will the one motorcycle with a 300 pound rider aboard that makes peak power at 5500 RPM throw you off in less than a second and the one that does it at 8500 RPM stall with all gearing being the same ?
Is that not what torque does ? more pulling power under a given load, so the lower RPM motor is more powerful at moving a heavier load all things being equal ?
  #142
Old 05-03-2015, 09:08 AM
Pocket's Avatar
Pocket
Pocket is offline
It's real simple.
STOP INTERCHANGING TORQUE AND HORSEPOWER. THEY ARE NOT SIMILAR UNITS OF MEASURE.
  #143
Old 05-03-2015, 03:25 PM
redford's Avatar
redford
redford is offline
Received 1,597 Likes on 933 Posts
Keep it civil, please.
  #144
Old 05-04-2015, 07:50 AM
Realslowww's Avatar
Realslowww
It's real simple.
Like I stated I pretty well understand it now , you break it down to a degree so thanks.
  #145
Old 05-07-2015, 08:53 AM
Diamnd1's Avatar
Diamnd1
Diamnd1 is offline
That would depend on how the force is delivered, for instance, Bruce Lee was small in stature, but could deliver a mighty blow.
  #146
Old 05-07-2015, 09:39 AM
airm4n's Avatar
airm4n
airm4n is offline
The semi I used to drive was rated for 550 hp but it put down around 2000 ft/lb or so it was rated for. However I think there are so many factors involved in figuring out that its easier just to find what works best for you than to try and compare a small pickup to a truck like that. Then you have to factor in the 3 drive axles and how it is split between them. The gearing in my opinion is the most important factor than any of the hp or torque numbers these manufacturers throw out there. I've seen a few automatic semi's with 100+ hp more along with the same torque rating than me but a higher gearing that couldn't pull an identical load up the same hill as me. They would start climbing and get to a point and the wheels would just stop turning. I'm also talking about 14% grade hills or bigger so you really get a good measure of what you can pull when you try to get 55,000lbs+ loads up there .
  #147
Old 05-07-2015, 12:10 PM
sky Cowboy's Avatar
sky Cowboy
sky Cowboy is offline
If you go to www.dictionary.com you can look up the definitions for horsepower and torque.
  #148
Old 05-07-2015, 12:35 PM
Fishin76's Avatar
Fishin76
Fishin76 is offline
You can't keep changing both variables when making a comparison..
one or the other is constant.. either torque, (size of fist), or HP (speed) is constant.
will a small fist do as much work as a big fist at the same speed? No..
I know what your argument is. A gasser can use RPM to it's advantage.. Well, kinda yes, and kinda no..
Gas engine's torque reading and HP reading cross on a dyno chart MUCH higher in the RPM band than diesel. At high RPMs, TQ drops off (sometimes drastically) and the gap between torque and HP gets bigger the more RPMS you turn.
So, can more RPMs help a gasser?
Yes, if you run it at the RPMs where TQ and HP cross.. Think of punching fast with a normal fist. (i.e towing somewhere around 55 in 1:1 trans ratio. (for me, thats 3rd gear))
No, if your running way up in the range near the red line. think of punching faster with a smaller fist... (i.e drag racing in an empty truck)
Running at the rpms that constitute peak torque, Think of punching slower with a bigger fist.. (i.e. pulling power, getting a load to move)
Your comment seems to kinda humanize TQ and HP, and it can't be compared that way. Humans are irrational and emotional. TQ is rational, and scientific. It does not care about momentum, (big guy, small guy theory) or how it is used. Momentum only prolongs the TQ event. (e.g hitting a wall with your fist, (short duration TQ event, or driving your fist through it, (long TQ event)), does not add torque, only prolongs how long you can maintain TQ. Momentum in an engine varies with RPM, but the difference of a few thousand RPMS while under a load is very minimal. Generally, it is pretty constant in an engine.
  #149
Old 05-07-2015, 01:09 PM
sky Cowboy's Avatar
sky Cowboy
Different engines turn at different ideal speeds by design.
Your diesel maybe pulls good at 2000 rpm....but it cannot spin at 5000 rpm.
Your gas maybe pulls best at 4000 rpm because that is its design.
A rotary engine may work best at 7000 rpm because that is its design.
A motorcycle may work best at 14000 rpm....again by design.
A jet engine may work best at 36000 rpm....yup you guessed it. By design.
If your working any engine hard and need it to produce full power just run it at the appropriate rpm for its intended design.
Comparing it otherwise is pointless.
The turbines in my helicopter make way more power than your ford diesel. But at a different rpm.
A huge engine to run a generator station that powers say a small village will make a lot more than my helicopter can.
Just run what you have at the right rpm for it and stop worrying about if it turns more rpm.
Pulling your trailer up a hill just do it where your particular engine design works best.
If diesels are so much better at making power why do the dragsters in NHRA not run them?
Its silly to argue apples to fish boats.
If you want more power buy a huge engine like used in a generating station.....nope not practical. .....but damn they make massive amounts of power.
  #150
Old 05-07-2015, 01:55 PM
Fishin76's Avatar
Fishin76
Fishin76 is offline
If your working any engine hard and need it to produce full power just run it at the appropriate rpm for its intended design. I agree, but the argument is which is the better design for towing and pulling.
If diesels are so much better at making power why do the dragsters in NHRA not run them? Because the weigh up to 3 times more than a gasoline engine of the same displacement due to the block strength needed for high compression (9.5:1 vs. 17:1)
Its silly to argue apples to fish boats. what????
If you want more power buy a huge engine like used in a generating station.....nope not practical. .....but damn they make massive amounts of power. YES THEY DO!! (Previous experience with 3600 series V12 Cat gensets..)
Quick Reply: V10 Gas vs Diesel "The Truth"
