No Electrical Power
Old Nov 23, 2004 | 08:47 PM
wolf81's Avatar
wolf81
No Electrical Power
I have No Headlights no power anywhere, I can turn key to on at switch and hotwire to start my truck..at the solenoid ..After starting I can turn off with key at switch. Note: If I turn my headlight switch on, while truck is running it will stall.. Do any of you all no what I need to check? .... Thanks dave
Old Nov 23, 2004 | 10:05 PM
LxMan1's Avatar
LxMan1
What are you working on?
Old Nov 23, 2004 | 10:58 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
my 76 F-150 did that...sometimes when i tried to start it everything would seem dead even with a charged battery...then sometimes driving down the road everything would shut down on me lights and all....turned out it was the big red wire coming off my alternator...it was old and brittle...looked good on the outside but inside the wires were busted up....u might look there........tell me if it works 4 ya....
SwOkcOffRoader
Old Nov 24, 2004 | 06:27 AM
wolf81's Avatar
wolf81
Originally Posted by wolf81
I have No Headlights no power anywhere, I can turn key to on at switch, start my truck..at the solenoid (Hotwire) ..After starting I can turn off with key at switch. Note: If I turn my headlight switch on, while truck is running it will stall.. Do any of you all no what I need to check? .... Thanks dave
1979 Ford F150 4x4 Shot Wheel Base
