Sponsored by: Real Truck
NO oil pressure
Old Nov 23, 2004 | 06:53 PM
jeffnoel's Avatar
jeffnoel
NO oil pressure
Howdy, Ive got a 2001 SD and last Monday I got the scare of my life. The engine has 80k+ miles, I started it and let it run for a couple minutes to clear the windows then as I drove down the street I looked at the dash and the oil pressure gauge was at 0. I listened for a second and eveything sounded normal so I spun a U to go back home and all the sudden the needle pops up to where it should be. It didn't happen again all that week, then this Monday after sitting for a couple days it did it again. The oi pressure gauge stays at 0 until the engine starts to warm then reads normal. Does this sound like a sending unit or gauge problem? Thanks
Jeff
Old Nov 23, 2004 | 07:14 PM
slc10844's Avatar
slc10844
Have you checked the oil level? What engine?
Old Nov 23, 2004 | 07:26 PM
Bob Ayers's Avatar
Bob Ayers
Symptoms sound like a bad oil pressure sending unit "switch".
Old Nov 23, 2004 | 09:08 PM
jeffnoel's Avatar
jeffnoel
Oil level is good, 5.4L, It only seems to do it after sitting for a couple days. It is parked outside and temps have been in the 30s and 40s at night lately.
Old Nov 23, 2004 | 09:32 PM
flathead239's Avatar
flathead239
Sending unit
Had this same prob on a 150 w/ 4.6 - replace the switch.
Jeff
Old Nov 23, 2004 | 09:36 PM
FortyFords's Avatar
FortyFords
I would not fool around with this symptom of no oil pres.There have been engines spin bearings on here the last couple months
2) 5.4 and 2)6.8 v-10's
reason= bad oil pumps and overdue oil changes
Get a real oil guage on the truck or take it in and have it chkd out.
Better safe than waiting for something to happen
Rich
Old Nov 24, 2004 | 12:35 AM
etcetera's Avatar
etcetera
Better safe than sorry, but you would definetely hear it if it really had Zero pressure.
Eric
Old Nov 24, 2004 | 04:02 AM
slc10844's Avatar
slc10844
At the very least, replace the sending unit/switch. You may want to consider an oil and filter change.
