Lifting a 79 f150
Old Nov 23, 2004 | 12:09 PM
sugar's Avatar
sugar
Lifting a 79 f150
Want to lift my 79 4x4 six inches. Any one do this without spending much on a suspension lift kit??
Old Nov 23, 2004 | 06:46 PM
teds74ford's Avatar
teds74ford
You could fab lowered suspension mounting points. Unless you have fab-ability, you would probably be better off to just buy a lift kit. Even then, the suspension is 20 years old, so a new one wouldn't hurt it.
Old Nov 24, 2004 | 01:58 AM
beaver77's Avatar
beaver77
Smile
I recomend the skyjacker lift with all the springs. I have the 6 inch lift on my 77 f 150 and it works great. It is not cheap but worth the extra money.
Old Nov 24, 2004 | 07:07 AM
sugar's Avatar
sugar
I priced out the skyjacker lift, ya pretty pricey, about 1300 canadian. Thought I could save money by doing it myself.
Old Nov 24, 2004 | 07:14 AM
sugar's Avatar
sugar
I do have fab experience, just need a little instruction.
Old Nov 24, 2004 | 08:03 AM
marcveinotte's Avatar
marcveinotte
Where in Canada are you?
Old Nov 24, 2004 | 09:33 AM
sugar's Avatar
sugar
Belleville, Ontario.
Old Nov 24, 2004 | 10:21 AM
samickguy15's Avatar
samickguy15
Lift
There's a place that sells 6" kits in my 4-wheel magazine for around $250 US. I can't remember who makes it or where my magazine is, but I think it comes with front springs, rear blocks, U-bolts, and the front axle bushings. I'll try to find my magazine.
Best of luck
Old Nov 24, 2004 | 10:36 AM
sugar's Avatar
sugar
Thanks, appreciate the info.
Old Dec 8, 2004 | 12:59 PM
samickguy15
Lift Kit
The magazine I was thinking of is Offroad Adventures. The kit is made by Skyjacker. It appears that it's $268 (US) for a 6" kit. which is front coils, pitman arm, and rear blocks. If you opt for the rear springs you can tack on another $400 or so. Check out www.fourwheelsupply.com
Do a search for the lines on the left:
176PKS 6" kit with springs
176PK 6" kit with blocks
179PKS 9" kit with springs
179PK 9" kit with blocks
174PKS 4" kit with springs
174PK 4" kit with blocks
Best of luck
Old Dec 8, 2004 | 07:53 PM
Hardcore4x4er's Avatar
Hardcore4x4er
do a shakel reversal in the rear which will give u about four inches and then buy six inch coils for the front, all u need to do is make up the two inches in the rear, I would use blocks.
Old Dec 8, 2004 | 08:29 PM
hillbillyk's Avatar
hillbillyk
www.broncograveyard.com has lift kits and they are priced very well, all kinds of different kit options. They are also a sponsor
Old Dec 10, 2004 | 06:46 PM
project supercab's Avatar
project supercab
Mine's got 2x4 tubing welded as spacers under the coil spring perches and the radius arm mounts with custom crossmembers to hold it all together fits 35" bfg's with 8" between the tire and fender! cheap
RustyShackelford
WTB - Parts & other
Nov 28, 2010 09:40 AM
Dennis H
Jan 22, 2008 10:33 AM
stang30
Feb 5, 2005 10:03 PM
bigredford04
Jul 17, 2002 07:53 PM
chieff
Jan 16, 2001 05:38 AM
