surging motor
Old Nov 23, 2004 | 11:10 AM
kaelor's Avatar
kaelor
surging motor
This is my first post and I am looking for some help with my truck motor. I just put an rv cam into my 88 f 150 302 efi. It runs great and the bottom end pull is fantastic. But every once in a while the motor starts to surge. the revs would drop to about 4-500 and then surge to about 1500 and then drop again. It doesn't happen all the time and I am trying to determine if it is when the motor is hot or not but there doesnt seem to be any specific time that this surge will start. Any one have any ideas on what is happening or how I can cure this would be greatly appreciated.
Old Nov 24, 2004 | 01:26 AM
Joboo's Avatar
Joboo
kaelor, this problem originated only after you installed the new cam? You say rv cam. Does this mean a ford cam that was the number listed for the same engine in an rv application or an aftermarket hi-po cam that supposedly has "rv" performance charachteristics? Either way, is it by chance some super high lift, high durration cam that is causing the lope? Could you have bought a mild cam that was either ground wrong or boxed wrong and is really the cam for a top fueler?
If the cam is not the issue i would suspect you have an issue with the iac/isc. A vaccum leak could be causing the iac/isc to be not responsive because it is out of range. I hate to ask, but did someone adjust the non adjustable throttle plate stop screw that is ofter mistaken for an idle adjustment? This would cause the identical problem to what you described.
Hope it gives you a starting point and some questions to think though. Good luck.
Old Nov 24, 2004 | 05:04 AM
SRD4X4's Avatar
SRD4X4
I agree with joboo, sounds like iac.Probably just a coincidence it happened after cam install.
Old Nov 24, 2004 | 09:59 AM
Archael's Avatar
Archael
goo...the screw that's behind that plate that's connected to the throttle linkage isn't the idle adjustment screw???...oops.
i believe i'm missing a vaccum line from my iac i dont' know where it starts tho so i can't find it. Could someone lead me to the other end of the vacuum line that's supposed to be there.
Skyline Drive
16
Nov 29, 2011 04:01 AM
cajunsuperduty
Oct 28, 2011 03:31 PM
chucknmesa
Jun 23, 2011 05:04 PM
charlie calcote
20
Mar 16, 2007 08:12 PM
albatrosss
Aug 2, 2004 08:19 AM
