My 97 always has what I call a surge, then drop in rpm, then surge, then drop in rpm at start up in the morning. The best I can describe it is, it sounds like it goes vrumm, vrumm. Does this about 4 or 5 times then runs fine. Is this due to air in my fuel line?
That is the glow plugs kicking in and out. It is normal. It is a on/off surge of the electrical system (GPs) causing the engine rpm to vary due to the increased strain on the alternator.
Reason: ...
Is It a "rough" surge?one of my trucks does what your describing but some what violent... I'm going to pull the crappy chip it came with one day and see if that is it for some reason, but I thinking I'll try to throw a eot sensor at it as this also effects start up... Just a thought and subscription!
FWIW, The engine I just swapped into my truck was doing this in the truck it came out of. When I had it on the engine stand, I did quite a few things to it, but the only one I think could have affected this issue was that I replaced the IPR o-rings. Now in the new truck, it doesn't surge or romp at all. I have heard that this surge can be caused by the IPR stroking wildly trying to control ICP. Not 100% positive that the IPR o-rings are what solved it for me, but it might be worth a try.
Oh, and 2x on doubting that it is being caused by the GP's.
If you have an auto trans , try starting it in neutral . May need a TRS ..
Not saying that's not the OP's issue but my donor truck was a ZF5 and mine is an E4OD, so that wasn't the issue for me. Not sure if this post was directed to me or the OP...
Just to anyone it may apply to. Surge at start up means the PCM is confused by the info its getting ..Leaking or bad ICP sensor , of bad connection may also be the case ...
Reason I talk about the GPs is, mine does this when its cold, like 15 degrees. When I start my truck, the GPs run for a short time as shown by my volt gauge reading like 10 volts.
Then a few moments later as I watch the volt gauge and RPMs I see it surge up and down about 100-200 rpms and the volt gauge also goes up and down (10v-14v) with the rpm. This lasts only for a few moments and the GP system turns off and the rpms stop surging and the volt gauge reads the normal 14v.
It may not necessarily be the GPs themselves, but something with GP system, maybe with the PCM or another sensor.
If my truck is plugged in or its warm, I haven't seen it do it. Just my $.02.
Thanks. I do have an oily ICP sensor. i've been puttin off replacing that thing. theyre so dang expensive. what the heck makes them so expensive? platinum innards????????
IMHO the draw of the GP's is constance and should not be the cause of the situation. Does your amp gauge jump up and down?
That's not just your humble opinion, that's how it works. Glow plugs cycling on and of is NOT, contrary to the previous post, normal! They're programmed to go on, stay on for a few seconds to up to two minutes, then shut off. If they're cycling on and off, that's probably because the glow plugs are pulling too much current, and overloading the relay, and it's cutting itself out.
But in the OP's case, if it's only romping 4-5 times, it's probably not this anyway. Sounds more like a fuel pressure / HP oil pressure thing. Might be worth checking the level of the HPOP reservoir and/or the fuel bowl before a startup sometime.
If it is truly the "romps" at start up it is usually an electrical signal issue . May be due to the ICP sensor or wire as I said , or a slow to respond IPR also .. The PCM can't see fuel pressure . SLow up and down idle can be from something as simple as a plugged FPR screen ...
