Air Bag Light
Old Nov 23, 2004 | 08:54 AM
HollywoodF-150's Avatar
HollywoodF-150
Air Bag Light
Good Morning Guys I have a simple question, If you know air bag codes. It just started to flash 2 1 then a long delay. I used to have the codes written down, but I have lost them.
THanks for you help
Old Nov 24, 2004 | 01:35 AM
Joboo's Avatar
Joboo
Hollywood, what year? Did you scan it and get a 21 or are you just observing the sir light?
Old Nov 24, 2004 | 08:47 AM
HollywoodF-150
It is a 94 f-150 with a 351. I am just going by the air bag light. I replaced the clock spring 2 years ago. I havn't put it on a scanner yet. I am hoping it isn't that again.
Thanks for any help you can give
Old Nov 25, 2004 | 11:48 PM
Fomoko1's Avatar
Fomoko1
What is involved in repalcing the clock spring? I have a 96 F250 with the flashing air bag lite and cruise not working. The horn still works.
Old Nov 26, 2004 | 02:05 AM
themoonshineboy's Avatar
themoonshineboy
fomoko1
Funny that this came up, I just replaced the clock spring in my 94 F150 air bag code 32, no cruise or horn and I put in a new wiper switch too. You have to pull the wheel and clock spring to do that too. I'll post the link that was most helpful https://www.ford-trucks.com/forums/s...d.php?t=236322
You also need to pop the ignition lock out too, easy job. Turn the key to the run position and push a long #1 or Philly driver into the little pin and pull the lock out. The bolts the hold the clock spring were torx head on mine as were the wiper/turn/hazard switch. If you have delay wipers I recommend replacing the switch at this time as it will go out as many have.
Be careful with the air bag. I left my truck sit for an hour to discharge the back up battery with the + cable removed from the batt and starter relay, this is done to prevent any one from walking past and setting the cable back on the batt. Also do not touch the pins of the air bag connector with anything as this could set it off!
Treat the bag as if it was a land mine!! Set it in a safe place and carry it with the back side away your chest. The metal side will most likely kill you if it go's off!!!
After that its all simple
Tool list
Torx driver/Clock spring,wiper switch
Deep well socket/ for removing the air bag from the wheel
2 thin blade screwdrivers for trim removal and the like
steering wheel puller
skinny Phillips driver #1/Ign lock
#2 Phillip driver/column trim
socket or nut driver/lower dash trim panel
The clock spring cost me around $120 here in WI from the dealer.
PS static electricity is not your friend while handling the air bag, so don't make any balloon animals when doing this job.lol
Old Nov 26, 2004 | 11:21 PM
Fomoko1's Avatar
Fomoko1
Originally Posted by themoonshineboy
fomoko1
Tool list
Thank you. On our 98 Ranger I got tagged for about $350 for this same repair. On my work truck (96 F250) I may get up enough courage to do this on my own as I can get the parts from a Ford dealer for about $50-55. Don`t like the idea of messing with the air bag but it will be much cheaper I hope.
