So far in Oregon, temps have been down into the low 30's. So right now I am experimenting with 4-6 hours to see what is the right amount of time. 5 hours seems to be the ticket right now. I am working down to 4 hours next week, then 3 the week after. After that, I will see what worked the best for the truck. Good luck!
There is another thread regarding this topic in the past week or so...
The wattage pulled by the heater is +1,000 watts and 3 hours is about right. However, leaving plugged in all night is not a problem, but some would say it is a waste of energy and undo usage of your heater element.
If you use an extension cord, make sure it capable of the wattage draw and if using a timer, use a 3-plug grounded unit rated for +1,000 watts.
Good luck,
I didn't realize the heater uses that much wattage
Mine gets plugged in the moment I pull in the garage, and doesn't get unplugged until I leave...it has been on for as long as 3 days straight...
You should also use an extension cord long enough that you can drape it over the driver's side mirror as a reminder that your truck is plugged in. That way you won't end up in the "what is that orange snake chasing me down the road?!" situation that, oh, maybe one or two of us have experienced in the past...
Tell you what.....If you have a generator that powers at least 2000 watts.....use your generator, keep the electric bill down......thats what I do.....and it doesn't use much as far as fuel consumption. Just my one cent.
Cost to buy - already justified to wife (TO LATE ITS DONE)!!!
Gasoline - Must fill with a gallon or two (have to buy and refill).
Storage - Must exhaust outside or run outside - hassel in cold weather.
Oil changes - Must change generator oil no and then (cold and dirty).
For the few hours a day (on a timer if need be) it would seem that your electric costs would be less if not the same and save the wear and tear on the generator and save it for true power outages.
Seems like overkill and "wired thinking" to me... but what the heck, your entitled to your wrong opinion... it is America (just funning with ya).
Depends on the location and temperature. At 20 above we plug in for a couple of hours, at -20 below we leave it plugged in at least 4 hours if not all the time. This is Alaska though and you will get various opinions. :-)
Good luck,
Just a thought here. I have a heated water bucket for my dogs when they are outside during the day That $20 bucket has a cord and a heater but it doesn't kick on till 40 degrees.even when pluged in ,and then of course it cuts out when the water reaches that 40 degree tempature.
Wouldn't the same hold true for the heater in the truck. If the heater is pluged in it would not continue to throw 1000 watts of juice to the block if it is heated to a certain temp. wouldnt that be a safety hazzard if it did.So if the block heater cuts off and turns on at pre-set temps would that not make a timer redundant and unnessasary?
Savage Sam,
saw these in Toronto recently, triggers by ambient
temp, but @ $ 140.00 each, now if FTE was to offer a group buy...........?? http://www.iplc.com/index.html
Nope, the block heater has no thermostat or control logic; it's just a big darn chunk of wire with electricity flowing through it and making it hot. A 1000W block heater can't possibly heat the coolant and block to anywhere near normal operating temps, so there's no safety hazard. As long as it's plugged in, your electric bill is climbing. In cold weather it reaches equilibrium, not able to heat the block any farther, after 3 or 4 hours, so any more than that is just wasted electricity (which may or may not be more valuable than your time or expense or hassle to limit the block heating to just 3 or 4 hours!)
