Bronco II Ford Bronco II
Need Help With Leaking Window
Old Nov 22, 2004 | 06:39 PM
rch's Avatar
rch
need a place to find window seals for the back windows, got a pretty good leak going on. search several places but can't find the right one for my problem. any ideas on where I can find the window seal? thanks
Old Nov 24, 2004 | 02:42 AM
turborich's Avatar
turborich
are you talking about the big side windows? if its a 86 or newer then i just had the same problem. some kids shot out my window with a pellet gun, so i got another window, but i couldn't find the proper sealer. the factory sealant was like a sticky two sided foam tape. nobody had it. so i bought what was avalible. it was a black round sticky type of stuff on a big roll. i cant remember who it was made by, but it was called window weld. it worked great and there are no leaks. if you have a 85 or older b II then i think it is held in place with sealant but im not sure. by the way the 86 up windows come out by removing the nuts that are behind the interior panels, i think there is 10 of them.
