Sponsored by: Auxito
Speedometer Adjustment
Old Nov 22, 2004 | 03:56 PM
Ben34's Avatar
Ben34
Hello,
i am going to install larger tires(265/75r16) on my truck to replace the stock 255/70r16's. i have heard that the speedometer will be off approximately 5 mph. is there a gear to change or is the speedometer all electronic and needs to be reprogrammed? btw, i have a 4.2 v-6 and 5-speed.
Old Nov 22, 2004 | 06:49 PM
triton_2002's Avatar
triton_2002
It electonic controlled. The dealer can reprogram it (not sure if they all do it) or you can get a Diable/Hypertech type programmer and do it yourself. Although that isn't much of a difference in tire height difference. I wouldn't bother.
Old Nov 23, 2004 | 01:39 AM
98NascarF150's Avatar
98NascarF150
i dont think that it would effect your speedo that much
Old Nov 23, 2004 | 03:28 AM
tofer76's Avatar
tofer76
how about 245 to 285
Old Nov 23, 2004 | 08:10 AM
Ben34's Avatar
Ben34
thanks, i guess I will see first how much it changes it and go from there.
Old Apr 20, 2005 | 09:27 AM
ScubaSteve's Avatar
ScubaSteve
I did the same tire change. My speedo is off by 10%. I'm trying to figure out how to calibrate it ATT. I have a '98 F150, 4.6L with the 4R70W tranny, and am told that the programmers (Diablo and Superchips) only work on a digital speedo. Is the output of a 4R70W digital? If so, then the programmers should work?? If the output isn't compatible, then how do we adjust for tires and rear gear changes???
Old Apr 20, 2005 | 12:27 PM
fordman311's Avatar
fordman311
No, 97-98 cant be reprogrammed. As far as I know. Gears you can do but they kidna $$$. Only thing that I have found thats resonable is this thing Superlift has. its called TruSpeed. It installs "in-line" to the odometer. like $200. I also hear of people putting in a gear box or something?? not sure about that. But i know TruSpeed works. Starting in the 1999 year the reprogammers work.
Old Apr 20, 2005 | 05:50 PM
fordman311's Avatar
fordman311
I didnt mean odometer. Just check out what superlift has to say about it:
The TruSpeed module installs in-line with the factory electronic speed sensor and converts the wrong speed signal into the correct one for your vehicle's new tire and/or axle gear ratio combination. Because the signal is altered at its source, all speed-sensitive vehicle systems will receive the correct speed data, which restores all proper functions.
ibewshooter
2015 - 2020 F150
Sep 27, 2017 05:32 AM
MONAVIERONJON
Aug 10, 2016 06:32 PM
Turmand
1983 - 2012 Ranger & B-Series
Mar 15, 2015 10:54 AM
metal13x
1997 - 2003 F150
Feb 6, 2008 01:13 PM
supercrewz
Georgia Chapter
Dec 21, 2004 10:57 PM
