Shifting
Old Nov 22, 2004 | 03:10 PM
dblakney's Avatar
dblakney
Shifting
My 94 F150 seems to grab a little when I shift. Does not matter what gear. Appears to be worst in the morning. Mazda trany. 5 speed. 302.
Any Ideas out there.
Old Nov 22, 2004 | 03:30 PM
sixpack2639's Avatar
sixpack2639
What do you mean by "grab a little"?
Old Nov 22, 2004 | 03:31 PM
dblakney's Avatar
dblakney
It's not a Smooth Shift. Feels like I have to force it a little, I can feel the gears in the shifter, like its not wide open.
Old Nov 22, 2004 | 03:34 PM
sixpack2639
Slave is probably weak or going bad. I just replaced mine for the same problem. You should also check your clutch master cylinder. Try bleeding the slave first. It's just like bleeding breaks.
