front u joints
Old Nov 21, 2004 | 12:00 PM
Dingus's Avatar
Dingus
front u joints
ive got a 1994 f150.im putting new upper and lowwer ball joints in it .at the same time i want to change the 3 u joints.will every thing just slide out of the front differential or is their a clip inside holding the middle ujoint from sliding out.
Old Nov 21, 2004 | 12:51 PM
andym's Avatar
andym
The driver's side will slide right out. For the passenger's side, there's a boot with metal clips at both ends holding it in place over the slip joint. If you cut one of the clips off, you can pull the axle apart at the slip joint.
Old Nov 21, 2004 | 01:35 PM
Dingus's Avatar
Dingus
andym will the middle joint with the boot on it slid right out too.
Old Nov 21, 2004 | 01:38 PM
andym's Avatar
andym
The inboard axle shaft won't come out, but the outboard side will. The slip joint will separate at the boot.
Old Nov 21, 2004 | 01:44 PM
Dingus's Avatar
Dingus
how do i get the in board axle shaft out to replace the middle u joint
Old Nov 21, 2004 | 07:00 PM
andym's Avatar
andym
For that, you will have to pull the front diff out and remove the clip.
Old Nov 22, 2004 | 05:15 PM
Dingus's Avatar
Dingus
Cool
thanks andym.thats not what i wanted to hear but i thought thats what had to be done.
