rattling/thumping noise
Old Nov 22, 2004 | 01:41 PM
bIIcool's Avatar
bIIcool
Question rattling/thumping noise
I have a 1990 Bronco II with a 5 speed manual transmission. Just last week I started hearing a rattling noise. It goes away when I press the clutch pedal down. It was present when in all gears and when it is in neutral. I had assumed it was the throw-out bearing. Just this weekend I replaced the clutch, pressure plate, pilot bearing, and throw-out bearing. I am still hearing the rattling. I am confused about this.
Old Nov 22, 2004 | 02:16 PM
sixpack2639's Avatar
sixpack2639
Check all of your heat shields. Mine work loose every once in a while and i get the same problem.
Old Nov 24, 2004 | 01:25 PM
bIIcool's Avatar
bIIcool
None of my heat shields are loose.
