Bad UJoint??? 94 Explorer
Old Dec 21, 2004 | 01:04 PM
mrshorty's Avatar
mrshorty
Originally Posted by niteowl
How would you test condition 1? Just grab the shaft and see if it has enough slop to move it? Or do you need to exert more force on it and use something to pry and look for movement? I have no experience with them.
By hand should be enough to tell.
I haven't seen any good way to change the outer u-joints in vehicle. That u-joint is tucked up inside the i-beam, and I think it would be overly difficult to get your tools on the joint. It's really not too bad getting the outer shaft out.
I understand the hesitation in tackling a job you've never done before. I'm often leery of tackling new jobs, too. Review the procedure in your Haynes manual and maybe a couple of other manuals (the vehicle repair guides at www.autozone.com contain the same information as Chiltons and also has an adequate description of the procedure). If you have any specific steps you don't understand, ask away -- that's what we're here for. If you feel like you understand what's being asked, then take your time, pay attention to what your doing, and I think you'll be fine.
zxwut?
34
Sep 23, 2024 10:08 PM
jason832
Sep 21, 2016 08:45 AM
dpilot83
Dec 23, 2015 09:43 AM
Ruffinit
1983 - 2012 Ranger & B-Series
Jan 24, 2012 10:02 AM
rocketman64
Feb 13, 2010 10:15 AM
