ford wiring help
Old Nov 21, 2004 | 04:58 PM
DMAN's Avatar
DMAN
ford wiring help
I have an 84 f-250 and the dash lights and the signal lights stoped working were should I start looking.
Old Nov 21, 2004 | 05:05 PM
Morky's Avatar
Morky
proly already checked this,
but I would start at the fuse box, checking all fuses.
as far as the signal lights,
where did they stop working,? the indicators in the dash ?
or the lights them selves.
maybe a flasher problem for this one.
or maybe burned out bulbs.
Old Nov 21, 2004 | 05:23 PM
DMAN's Avatar
DMAN
Not the bulbs or the flasher. I just tested it and I'am not geting any power to the flasher. The four-ways work though. As for the dash lights they just stoped working I don't have a clue were to look on that one.
Old Nov 21, 2004 | 08:29 PM
Lee Lichterman's Avatar
Lee Lichterman
My diagram looks like it is two different problems best I can tell.
Flasher works because it gets it's power from the battery always hot terminal.
Turn signals gets it's power at the flasher which gets it's power from fuse 5 which comes from a gray/yellow wire coming from the ignition switch pin A2
Dash lights get power from light blue/red wire getting power at fuse 17 from the headlight switch.
Do your back up lights work? I show they share the same power as the turn signals from fuse 5 but take their power before the flasher directly from the input side of the flasher coming out on a purple/orange wire. Turn signal comes out the other side of the flasher on a blue wire and runs to the column turn switch.
Lee
