Fuel Filter's
Old Nov 21, 2004 | 03:49 PM
satcom40's Avatar
satcom40
Fuel Filter's
How often doe's the fuel filter need to be change on the 04 f250 6.0L
Thanks for the Help
Old Nov 21, 2004 | 04:20 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
I am not sure it is there...however check out the "Teck Folder"
Old Nov 21, 2004 | 05:02 PM
GTOBRIAN's Avatar
GTOBRIAN
If its the same as my 03', the fuel filter and water seperator should be changed every 15000 miles, as per the 6.0 liter owners manuel supplement.
Old Nov 21, 2004 | 05:34 PM
eharman's Avatar
eharman
It is in the owner's manual.
EJ
Old Nov 21, 2004 | 06:44 PM
satcom40's Avatar
satcom40
OK I see what the book says, but what about all of our Senior user's, sooner or later
Old Nov 21, 2004 | 08:18 PM
IB Tim's Avatar
IB Tim
I drain my water every 2k, have not hit the miliage to change the filter...
Old Nov 22, 2004 | 05:27 AM
thannock's Avatar
thannock
I have a 04 6.0l with 22,000 on it. I wasn't aware of the 15,000 mile fuel filter changes until 19.000 miles were aleady on it. Yesterday, the water in the fuel light came on for the first time. I had to change the filters anyways, so I chose to change the filters. What a mess. Either I did something wrong or whatever, but I had diesel all over the driveway and myself when I changed the HCFM on the Frame Rail. After about an hour, I got it changes and proceeded to change the top mounted filter as well. The light is gone, but then again, a boat load of diesel was in my driveway. Does anyone have any ideas on changing the HCFM filter so that I'm not swimming in diesel in 9 months when 15,000 more miles have been racked up on my truck?
Thanks,
Ted
Old Nov 22, 2004 | 07:31 AM
IB Tim's Avatar
IB Tim
Thanks,
Ted
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum.
Be sure to check out the 6.0 Bible…..great reading
http://dan.prxy.org/Truck/6L_bible_html/html/TOC.html
http://www.backglass.org/duncan/ps60_manual/
…. In the upper right hand corner of your screen check this out PARTS SHOP for all your “trucking” needs
Must read
http://www.clubfte.com/users/monsta/SuperDutyFAQ.html
https://www.ford-trucks.com/forums/s...d.php?t=303583
Enjoy FTE
Old Nov 22, 2004 | 08:05 AM
moebdick's Avatar
moebdick
I haven't changed mine yet (it's still new...yeehaw!!), but I would drain it first, then put a catch pan under it when you change out the filter. Some folks have stated that draining the HFCM on a full tank results in more diesel being drained, possibly from siphon effect? (I'm not sure about this; haven't tried myself). If so, don't change it on a full tank.
Old Nov 22, 2004 | 08:59 AM
Mud Doc's Avatar
Mud Doc
Didn't change mine until 30,000--no water apparent, just some small flakes of ???
Light never came on. I have the 4x4 and its somewhat awkward to work around the front driveshaft, but doable. What I did: put some papers down, hoping not to have too much diesel run out; backed out the plug slowly until drip appeared; held a cup under the plug area and continued backing out the plug; it came to finger loose and was dripping regular--left it like that for 30-40 seconds, then unscrewed the plug rest of the way. Got about 10 oz of diesel into cup and it stopped dripping--don't remember how full the tank was. Replaced plug (I had purchased a second plug from Ford just in case the hex head stripped, as some have had happen--didn't need it) and tightened it back. Then, on to the filter itself--same procedure: loosen the filter cap slowly until it starts to drip, let it drip for awhile into a cup, then continue loosening until it becomes finger-loose. The drips will increase as it loosens--don't take it off completely until it almost stops dripping. When drips stop, or patience runs out, finish loosening the cap and take it off--more diesel will come out at this point and this is where the mess can occur. I got a total of less than 20 oz of diesel, and hardly had any cleanup to take care of.
Old Nov 22, 2004 | 09:20 AM
luckeydr's Avatar
luckeydr
Did mine at around 15K, point the nose slightly down lower than rear. Open fuel tank cap to relieve any pressure. I did top filter first. For the big one underneath, take out the water drain plug, let drain, take off the filter cap, some fuel will still drain out of here, replace filter, cap and drain plug. Turn key on for about 30 seconds. Cycle on and off about 2-4 times like this then start and go. This is what I did except the part about opening the fuel tank cap to relieve any pressure. After changing mine, I read about this on the dieselstop site, they say this will stop the siphoning effect. Nobody ever mentioned anything about tank quantity. Mine never stopped draining just changed the filter really fast to minimize the fuel leaking.
Old Nov 22, 2004 | 09:55 AM
SBV45's Avatar
SBV45
Check the tech folder and the fuel water drain procedure and fuel filter change procedure. It isn't just a reprint of the manual. It is a procedure written from experience from us who have gone through it. Take advantage of our experiences.
Old Nov 22, 2004 | 10:02 AM
IB Tim's Avatar
IB Tim
Maybe that should be the title of the Tech Folder
Old Nov 22, 2004 | 02:41 PM
thannock's Avatar
thannock
Thanks for the replies
To all,
Thanks for the replies. Tim, I actually read the 6.0L bible prior to doing the filter change. However, I didn't see the tech folder SBV45 referred too. Your site is excellent and I'd like to say thanks for all of the great information. I'll keep these ideas in mind in another 15,000 miles.
Ted
Old Nov 22, 2004 | 03:48 PM
IB Tim's Avatar
IB Tim
Click her for the folder
