starter relay on 86 efi
Old Nov 21, 2004 | 03:08 PM
motorheadmach1's Avatar
motorheadmach1
im workign on a 86 f150 2wd ocassionally wont start who knows where the starter relay is not the selinoid but a relay. theres one in the schematic maybe on teh inside firewall by the computer? thanks for the help.
Old Nov 21, 2004 | 05:37 PM
Holmesuser01's Avatar
Holmesuser01
Starter Solenoid
Unless there is something very different about your truck, I believe there is only one solenoid for your starter; the one beside your battery. There is no solenoid on your starter. One of the pole pieces on the starter is pulled into position by magnetism and thats what operates the starter bendix.
Your starter may be dying. I suggest you check the brushes on the motor. They are very replaceable, and if you can do it, cost much less than a new starter.
Best of luck to you.
Mike in Ohio
Nov 27, 2012 01:31 PM
kanepjk
Bronco II
Nov 24, 2006 01:24 PM
jimdandy
Electrical Systems/Wiring
Mar 4, 2006 08:17 PM
SoCalDesertRider
Dec 24, 2002 09:24 PM
TOUGHLover
1983 - 2012 Ranger & B-Series
Dec 5, 2002 06:13 PM
