Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Cleaning Ford Droppings?
Old Nov 20, 2004 | 10:13 PM
GotLift's Avatar
GotLift
My driveway is starting to look crappy from my oil leaks. What do you guys use to clean the concrete? I don't have a power washer, just a hose. Would simple green and a scrub brush cut it or do I need a more powerful chemical?
Thanks
Old Nov 20, 2004 | 11:47 PM
nick88f150's Avatar
nick88f150
I would think any kind of a grease cutting soap would do the trick, along with some good ole elbow grease (just dont drip any of that on the driveway, or you'll hafta scrub that too, haha).
Old Nov 21, 2004 | 06:36 PM
Gregg C.'s Avatar
Gregg C.
Speedy Dry and a BRICK! Start scrubbing!
Old Nov 21, 2004 | 08:17 PM
Aftrmidnite's Avatar
Aftrmidnite
Tide powder, put it on the driveway at the end of a good soaking rain storm. Dampen it and let it set for 3 to 4 hours, (overnight is even better) scrub with a stiff brush and hose off.
Old Nov 22, 2004 | 05:13 AM
Torque1st's Avatar
Torque1st
Posting Legend
Greg has a good answer. I have used cat litter or oil dry for years and just grind it into the surface with my foot. If you have a large area tho the Tide method may work better.
Old Nov 22, 2004 | 05:21 AM
GotLift's Avatar
GotLift
Cool, Thanks guys. I have detergent on hand so I'll try that this weekend. I don't have a huge area. I have two small areas from parking forward and backward in the driveway. I guess it's not bad considering I will have the Bronco for a year in December.
Old Nov 24, 2004 | 01:04 PM
rdually's Avatar
rdually
Found some stuff called "Pour and Restore" I found it at ACE it was a bit pricy and I believe you can find it elsewhere for less.
It is a white liquid, kinda of like a liquid comet, smells like citrus.
Pour it on the spill and as it drys it pulls the oil out of the concrete. After it drys you just brush it away.
Old Nov 25, 2004 | 01:42 AM
grease monkey's Avatar
grease monkey
I pour some liquid laundry detegent on the spill and let it sit for a bit and then get a scrub brush and use some elbowgrease and then rinse you will see a difference
Old Nov 25, 2004 | 10:22 AM
scottie2hottie's Avatar
scottie2hottie
laundry detergent is what I use on my garage floor....
Scott
Old Nov 25, 2004 | 10:45 AM
red01's Avatar
red01
try dry portland cement just por on stain scrub lightly and let set for a couple hours then sweep stain should be gone . have used this on un sealed concreate several times ..
Old Nov 25, 2004 | 12:26 PM
RR4E's Avatar
RR4E
Varsol does a pretty good job along with a stiff corn broom.
Old Nov 25, 2004 | 08:09 PM
Turbo Indian's Avatar
Turbo Indian
I was just reading this, I'm going to try it. like a dummy I changed the oil in my big rig on the slab in front of my shop
For example, the most popular concrete and grout cleaners on the market contain phosphoric acid. This acid will, under most circumstances, do as good a job as muriatic acid... but with less danger. Phosphoric acid cleaners also contain chemicals which emulsify oils to help the acid work more effectively and safely increase its cleaning properties
