Sponsored by: Auxito
start up engine tapping
Old Nov 20, 2004 | 09:58 PM
matt d's Avatar
matt d
My 2001 ford f-150 ,5.4 has a tapping on start up..it only persist's for 3 minute's and goes away.The dealership say's that it's normal operation ON SOME 98-01, 5.4 engines.The engine operate's fine and has'nt burned any oil.The truck only has 30k on it.I was wondering if anyone else has had this problem?
Old Nov 25, 2004 | 07:06 PM
Fat Ford Boy's Avatar
Fat Ford Boy
I too have a 2001. Was told that the oil comes from the bottom of the motor, and will hear a "tapping" from the engine, until the oil gets to the parts.
Old Nov 25, 2004 | 08:44 PM
JH6's Avatar
JH6
sounds like classic 5.4 piston slap to me.
What oil filter are you running, I would run a motorcraft filter if you aren't already doing so.
If you are using the right filter, then its just 5.4 piston slap.
Old Nov 27, 2004 | 10:38 AM
d0n_3d's Avatar
d0n_3d
the 5.4L motor has very tight clearances and that cold start ticking is indeed piston slap...it's perfectly normal and my truck does it too...to minimize this, you need to run 5w20 oil (preferably the motorcraft brand because it's part synthetic) and a good oil filter such as the motorcraft filter...i do notice a major difference in the noise when i switch from 5w30 in the summer to 5w20 in the winter...my truck has 100k miles on it now and is doing just fine...
eigenvector
1983 - 2012 Ranger & B-Series
Oct 31, 2016 08:00 PM
flyingtexan
Oct 28, 2016 10:52 AM
Coachhick
Jun 6, 2016 10:22 AM
jwdenney2
2004 - 2008 F150
Dec 23, 2015 01:15 AM
rodderz
Mar 2, 2015 07:39 AM
