Coil Spring Question
Old Nov 20, 2004 | 07:53 PM
Pahrump1's Avatar
Pahrump1
Are the coils on a 2WD SD the same as the coils on an X?
Real question is will the Daystar 2Wd 2" coil spacers work on a 2WD X?
Old Nov 21, 2004 | 01:39 AM
Monsta's Avatar
Monsta
Sit. Stay.
I would say yes.
I don't think the springs rates are the same (depending on the SD configuration) but the spacers should go right in.
Old Nov 21, 2004 | 11:16 AM
Pahrump1's Avatar
Pahrump1
Cool, so next question is should a 2WD lift kit for a SD fit an X?
Seems like it should, but for some reason the X lift is like $200 more???????
Old Nov 21, 2004 | 09:06 PM
xspeedyx's Avatar
xspeedyx
It is because the X needs springs to lift the rear not just blocks. Pro comp makes 4" lift rear leaf springs.
Old Nov 21, 2004 | 09:30 PM
Pahrump1's Avatar
Pahrump1
Ok, so the front end is the same I assume. But the X kit comes with springs and the SD kit just blocks. Cool, Now I know what to do.
Thanks alot.
