1978 - 1996 Big Bronco
Need a quick parts description!
Old Nov 20, 2004 | 03:30 PM
ripsterone's Avatar
ripsterone
I can't find my repair book and need to find the name of a part if some one can help me fast. The part is some sort of air filter that is connected to the block in the back of the motor on the right side if your facing it from the front of the truck. it seems that it broke off from the threads that screw to the block.
Old Nov 20, 2004 | 05:03 PM
bronco351's Avatar
bronco351
Can you tell us the year, make, model and engine in your Bronco.
Old Nov 20, 2004 | 08:26 PM
TxBrokenarrow's Avatar
TxBrokenarrow
Try this search in bronco forum (Hanging Tube)
Old Nov 21, 2004 | 02:11 PM
ripsterone's Avatar
ripsterone
95 bronco 5.0L
Old Nov 22, 2004 | 09:14 AM
broncobob's Avatar
broncobob
If it's the part I'm thinking of, its called an air check valve. It's part of the air injection (emissions) system. It has a hose fitting on the top that goes to a rubber hose, and about a 3/4" pipe thread on the bottom that threads into a pipe that goes between the back of the heads. The welds that hold the top part on to the threaded part don't seem to be very strong, at least on mine they didn't. I just replaced the one on my 94, it was less than $20 but lost a lot of skin getting it changed cause there isn't much room between the firewall and the back of the block on a 5.8.
Old Nov 22, 2004 | 09:37 AM
jdmorg's Avatar
jdmorg
While I may look like a thread hijacker, I'm not. What is a Thermactor? I've asked about a part--either the same exact one as ripsterone or an associated part--and this was the part name I was given. Is this a correct name?
