Bronco II Ford Bronco II
Transmission
Old Nov 20, 2004 | 11:53 AM
grumpyjjo's Avatar
grumpyjjo
Transmission
I am almost finished with my project. I have finished installing my 4.0L into my 89 Bronco II from a 91 explorer. The engine came from a 4X4 AUTOMATIC Explorer. My question (which I’ve asked before, but I can’t find the post that had the answer): Can I use my Mitsubishi 5 Speed transmission from my Bronco II on the 4.0L Engine? <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Is there anything else I need to be aware of besides having to change the STARTER, FLYWHEEL, BELL HOUSING, THROW OUT BEARING, CLUTCH, and PRESSURE PLATE (These components are not the same between a BII and Explorer)---in fact—the only thing that has been interchangeable is the slave cylinder.<o></o>
<o></o>
OR, Should I just pay the money and get a 91 Explorer Transmission. The transmission in my Bronco II doesn’t even have 15,000 miles on it and I would like to keep it if it will work.<o></o>
<o></o>
Thank you in advance.<o></o>
<o></o>
Jesse <o></o>
