Sponsored by: Innova
Series, Parallel, or Independent ???
Old Nov 19, 2004 | 05:19 PM
FAB150's Avatar
FAB150
Which is the best way to hook 1 DVC sub?
Old Nov 19, 2004 | 09:10 PM
grease monkey's Avatar
grease monkey
How many ohms is the sub and what is the ohms your amp is stable at and then I can tell you.
Old Nov 19, 2004 | 09:40 PM
White04CC's Avatar
White04CC
Hey GreaseMonkey.. If my subs are 4ohm . What does it do to bridge them down to 2 ohm, and can that be done?
Old Nov 19, 2004 | 10:28 PM
MemOrex's Avatar
MemOrex
White04CC, is this 2 subs we're talking about? Are they SVC?
If you bridge them down, ONLY if the Amp is 2 ohm stable, they're power will increase depending on the amp. How many channels is your amp.
Old Nov 19, 2004 | 10:31 PM
White04CC's Avatar
White04CC
Yes..2 svc Audiobahn 10s. They Are 4ohm. I have not bought the amp. I was wondering if i should just buy a mono amp or 2ch.
Old Nov 19, 2004 | 10:40 PM
grease monkey
Do you have 2 dvc 10s is what you are saying. Or are they single voice coiled. i would get a mono block if you could. Tell me if they are single or dual voice coiled and how many you have and I can give you an idea what ohms you can run. When you buy an amp you want to run the subs the lowest ohms that the amp can handle so there is alot less resistance. When there is low resistance the easier the amp can push the subs. Also you want to find out the rms of the subs before you buy a amp. Dont buy an amp lower than the rms of both subs because it could cause damage to the subs.
Old Nov 19, 2004 | 10:43 PM
White04CC's Avatar
White04CC
they are 4 ohm single voice coil. They are 450w rms.
Old Nov 19, 2004 | 10:56 PM
grease monkey
Heres the best you can do. If they are single voice coil. Buy a mono block that is 2 ohms stable rated at 900 watts or more. To wire those subs to 2 ohms hook the 2 positives together and hook the positive to the amp. Then hook the 2 negatives together and run it to the negitive of the amp and voila you have 2 ohms. You can also wire them to 8 ohms but that would suck so go for the 2 ohm load.
Old Nov 19, 2004 | 11:01 PM
White04CC's Avatar
White04CC
I appreciate that. Thats what i was kinda figuring. So do you think that 1000 watts would be sufficient?
Old Nov 19, 2004 | 11:06 PM
grease monkey
Yeah but dont crank the gain all the way up or it could be trouble. But double check that is the rms rating of each sub not the peak. Multiply the rms times two and you will have what size of amp you want. Under powering subs can freeze them up so its better to have more power because you can always adjust the gain. The rms is what you pay attention to more than peak.
Old Nov 19, 2004 | 11:08 PM
White04CC's Avatar
White04CC
http://cgi.ebay.com/ws/eBayISAPI.dll...ayphotohosting
what do you think about this one?
Old Nov 19, 2004 | 11:10 PM
grease monkey
The link isnt working put the item number down and then I will look at it
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
