Some more FE questions.......
Old Nov 19, 2004 | 04:48 PM
FERacing66's Avatar
FERacing66
Question Some more FE questions.......
Hello. I am still working on building my HI PEF 352. I have a few questions if you dont mind.
1) I have replacement bolts for the cam plate that holds the cam in at the front of the block, how much space should there be from the bolt head to the cam timing gear? Its very close but it is clearing the gear.
2) How tight should the cam be once the cam plate and the freeze plug at the back of the block are installed? Should there be any lateral movement at all?
3) What is the torqe supposed to be for the bolt that holds the cam timing gear to the cam?
4) There is three oil holes at the rear of the block surronding the rear of the cam, should these be exposed or plugged?
5) How do you remove the old crank gear and install a new one? There is a little pin thing thats wedging it on, do I just tap it out and then tap it back in to install the new crank gear?
6) There is a smalle metal dowel that connects the cam to the cam timing gear. How far should this dowel be sticking out when the cam timing gear is installed?
Thank you so much for the help this website is invaluable to me. I wouldnt be building my new engine if it werent for the guys at FTE. Thanks your the best!
FERacing66
Old Nov 19, 2004 | 10:36 PM
Scouder's Avatar
Scouder
I will give these a try:
1. If the gear clears when it is pushed as far as it will go toward the bolts, you are fine.
2. The cam should turn freely, but there should be VERY little or no lateral movement.
3. The general consensus seems to be 45lbs.
4. The three holes need to be plugged. Otherwise you are going to shoot pressurized oil out the back of the block.
5. The crank gear (timing gear?) is held in place, to prevent spinning, by a key. Tap (or pull) it off, tap it on. They can be fairly tight.
6. I can't answer this one. I can't remember if the dowel drives the fuel pump eccentric or not.
Hope this helps.
-Scouder
Old Nov 19, 2004 | 10:39 PM
rusty70f100's Avatar
rusty70f100
I can help on #6. The dowel pin should be as far back in the cam as possible, and should be recessed a ways in the timing gear. The fuel pump eccentric has a kind of a tab in it that locates in the same hole, in the process holding the dowel pin in.
Old Nov 19, 2004 | 10:55 PM
Scouder's Avatar
Scouder
There you have it. I don't run a stock setup, so I couldn't remember how it went. Thanks.
-Scouder
Old Nov 20, 2004 | 01:33 AM
FERacing66's Avatar
FERacing66
That answered the questions, thanks again guys! My build will procced on schedule tommorw morning.
macubus
2004 - 2008 F150
Aug 3, 2019 01:03 PM
Nathan Vos
Apr 29, 2017 02:20 PM
palehorse13
Sep 23, 2012 04:27 PM
paintrx
Sep 19, 2012 10:59 PM
IntheTrees
Aug 4, 2009 07:19 AM
