88 Ranger 2.9L loading up
Old Nov 19, 2004 | 01:43 PM
gingo70's Avatar
gingo70
Angry 88 Ranger 2.9L loading up
My 1988 2.9L Ranger with 140,000 miles runs great most of the time. However, every once in a while the engine will start to "chug" and spew black smoke for about ten seconds, then it will snap out of it and run fine. I've replaced the o2, coolant temp, charge air temp, and throttle position sensors all to no avail. The check engine light does not come-on. I self-diagnosed it and came up with 2 koeo codes-----67 & 41. 67 is not listed in my manuel, 41 is, and says o2 sensor reading lean, Henceforth the inconsistent yet highly rich fuel mixture. What would cause this to happen intermittently, and not all the time? Better yet, what would even cause this? Oh....I almost forgot.....new fuel tank, high and low pressure pumps, air filter, plugs, wires.
Old Nov 19, 2004 | 08:46 PM
Ken00's Avatar
Ken00
The 67 is neutral switch or AC input.
Check the O2 wiring very carfully for the 41, sounds like you have a loose connection or damaged wire.
Old Nov 19, 2004 | 09:20 PM
vikin11's Avatar
vikin11
I feel your pain, thats the same thing mine was doing, i replaced everything...technician at wits end...it would run beautifuly for awhile then all of a sudden it would slow down and puke out black smoke, i had an 86, i finally ended up selling it...good luck in finding the elusive problem.
Michael
Old Nov 20, 2004 | 05:12 PM
dsldandually's Avatar
dsldandually
Pull the vacume line off the fuel preasure regulator if you have any fuel in there then the regulator is bad or going bad thats what mine was doing before it completely craped out.
Old Nov 20, 2004 | 07:32 PM
ol yeller's Avatar
ol yeller
son's 89 was the fuel pressure regulator. running great now
Old Nov 21, 2004 | 05:13 PM
gingo70's Avatar
gingo70
Thanks for the in-put guys. I started checking my manual and it said the MAP sensor controls fuel delivery and ignition timing. Since the MAP sensor was the only one I didn't replace, I replaced it. The truck runs fine now, I took it for a good long ride and it didn't miss a beat. I love my old 88 Ranger. Now I want one of them new Mustangs. Are they awesome, or what?
Old Nov 21, 2004 | 08:27 PM
Ken00's Avatar
Ken00
Glad to hear you got it fixed!!!
I'll take on of those Stangs too.
twigsV10
19
Feb 6, 2016 11:26 PM
deere842
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Aug 30, 2015 11:54 PM
Four.on.the.floor
Jul 2, 2015 06:56 AM
sh4rky514
Jun 3, 2015 08:17 PM
Backwoods351
20
Nov 20, 2014 06:29 PM
