does this sound right ? o2 sensor...
Old Jul 1, 2015 | 10:19 PM
Four.on.the.floor's Avatar
Four.on.the.floor
I recently purchased a 1986 ranger with a 2.9L with 89k miles and a rebuilt A4LD with paper work and it only has 5k on it. i bought it from the original owner. he had
its 4wd, 2.9L, and 4.10s around. its a great truck when it ran well
it started one day just randomly while driving. The symptoms are only present when engine is warm and at operating temperature. so when i started it in the morning it runs great and drives great and has all the power but as soon as it warms up ( in about 3-4 miles) it will slowly die if i press the peddle the rpms will decrease all the way to 0 but if i quickly press the pedal over and over again it will sorta creep along. But when say creep i mean around 5 mph. and it will die a lot of the time.
i pulled codes and got
41, 33, 13, 77, 25, 74
i replaced the TPS and the TFI-IV without any difference with the TPS but havent started it with the new TFI but i crawled under the truck to look at the o2 sensor and a white wire has been ripped out of the connector so it is not sending anything to the computer which i think it my real problem and hopefully when i replace it tomorrow it will fix it.
does that sound like a plausible problem from a faulty o2 sensor ?
Old Jul 2, 2015 | 06:43 AM
1986F150six's Avatar
1986F150six
I believe you are in the wrong forum, Four.on.the.floor. Try this one...
Ranger & B-Series - Ford Truck Enthusiasts Forums
Old Jul 2, 2015 | 06:56 AM
Franklin2's Avatar
Franklin2
O2 sensor being bad won't cause it not to run or run that badly. Now if one of the wires is shorted to metal somewhere, that might be a different story.
DPDISXR4Ti
Aug 2, 2012 10:08 AM
RacinNdrummin
Sep 16, 2006 06:45 PM
rocketroy
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jul 12, 2005 02:01 PM
the law
Mar 18, 2003 03:05 AM
KTMNealio
Nov 20, 2000 08:13 PM
