ok guys this is my problem my timeing gears and chain are shot--its a 78 f-250 4/4 i want to do away with that retarded set that in there no --so i went and bought a set for a 71 351c --is that the right set to buy --and do i have to do any thing diffrent or will this just bolt right in --sorry for the long post -just want to make sure i do this right--with your guys help i get it done-thanks
It should. Personally I went for a good set of aftermarket rollers and degreed my cam so I knew for sure that it was installed at 0 deg. I found out that when I installed the gears "straight up" my cam was less than half a deg off.
im a little cunfuzzed i got my old set out and the marks on the bottom gear is on top with the key way on top--and the top gear mark is on the top they dont meet in the middle like the book shows so how do i do the new one
mayby its me but i dont see no diffrents in these gears new from old i just no i dont want the retard timeing in there--boy they look the same to me--is the pin on the cam on top or bottom sorry guys im not to good at this stuff
Are You Sure Your At Top Dead Center???have You All Ready Pulled The Old Set Out???make Sure Distributer Rotor Is Pointing Towards The No1 Sparkplug On Your Cap
