What happened?????????????
Old Nov 19, 2004 | 12:59 PM
352 blue's Avatar
352 blue
Cool What happened?????????????
I replaced the thermostat and gasket in my 352 last Friday everything went great it cut the warm up time by 10 minutes the thermo was apparently not working. Until yesterday I noticed I was leaking antifreeze but not out the thermostat. I have antifreeze dripping off the bell housing. I'm thinkin I blew a head gasket because behind the drivers side had the seemed to be a particularly wet spot running down the block to that area. would this make sense? Have not had time to check compression.
Old Nov 19, 2004 | 01:01 PM
c_rossman's Avatar
c_rossman
Well, WIth the engine running warmer you are probably running higher pressure. It could be a frost plug too, That would involve pulling the motor if it is behind the bell housing.
Old Nov 19, 2004 | 05:03 PM
HOTWRENCH's Avatar
HOTWRENCH
Talking leak
Check the back of your intake sometimes they leak in the corners and run down the bell . Also check your heater core and hoses.
GOOD LUCK!!!!! HOTWRENCH
