which 351?
Old Nov 19, 2004 | 10:56 AM
badcuda's Avatar
badcuda
which 351?
new to fords. just bought my kid a 77 ford f150 has a 351. how do i tell if its a351 modified or 351 winsor or cleveland. and what is the prefered timing for this truck and motor thanks jc
Old Nov 19, 2004 | 11:16 AM
samickguy15's Avatar
samickguy15
Motor
You have a 351M (Modified, Midland, Mexican, blah blah blah). There's a very slim chance that somebody put a 351W in, replacing an I-6 or 302. If the water outlet (thermostat housing) is bolted on the end of the intake, then it's a Windsor. If it's on the top, then it's a Modified. As for timing....I would pick up a Chiltons or Haynes manual at your local auto parts store.
Best of luck to you and your son. The old Fords are the only way to ride.
Old Nov 19, 2004 | 01:16 PM
fatherdoug's Avatar
fatherdoug
The 351M thermostat housing goes on top of the block, not on top of the intake maifold. Also, there is difference in the fuel pump mounting bolts. The 'W' fuel pump bolts are mounted horizontally, and the 'M' bolts are mounted vertically.
Old Nov 19, 2004 | 02:09 PM
F150daniel's Avatar
F150daniel
it could have a 400 in it too. you can't tell the 351M and 400 apart from looking at the outside.
4th letter in VIN
S=400
H=351M
G=302
B=300 I6
preferred timing is 2° less than what it spark knocks at warmed up. back it off some if it starts slow.
-EDIT- You can make that little degree mark by holding down the ALT key and typing 248 on the numeric keypad. The ° will appear when you let up on the ALT key. -Admin
Old Nov 19, 2004 | 09:31 PM
Matts72's Avatar
Matts72
Factory timing is 8°-10° Before Top Dead Center. You will find that your timing chain is loose and you probably won't be able to set the timing exactly.
Old Nov 22, 2004 | 09:22 AM
badcuda's Avatar
badcuda
351 motor
thanks guys the motor endedup being a 351 windsor. found acouple of screwed up things the had the wrong gasket between the manifold and the carb plate and also there was no timing tab had to set it by ear. but sounds and runs better. although this engine is extremly slow to warmup in the mornings wants to bog down if you give it any gas. any suggetions here. has a 2 barrell carb
Old Nov 22, 2004 | 03:39 PM
F150daniel's Avatar
F150daniel
Is the accel pump working? with the ignition off look down the carb and open the throttle, you should see two streams of fuel hit the boosters.
the way i make the ˚ is hold ALT/ option key and press K.
-EDIT- unfortunately that does not always display a °, it displays a " or some other character. The ALT-K method only works in some programs. -Admin
Old Nov 23, 2004 | 12:02 AM
Jerry Gougeon's Avatar
Jerry Gougeon
Before you start screwing with the carb your bog could still be timing when you are doing it on a guess
Mine will do this as well if the timing is not quite right but it will idle and run like a charm otherwise . Good Luck to the young lad with his Ford Truck.
Old Nov 26, 2004 | 03:48 PM
alumataz22's Avatar
alumataz22
the bogging down could be from the choke staying closed for longer than it should, you can try adjusting the choke so it opens sooner.
Old Nov 27, 2004 | 07:13 PM
77300i6's Avatar
77300i6
Rip off that auto choke and do yourself a favor by putting on a manual choke. JMHO.
navyflyinggreg
23
Apr 22, 2007 08:07 AM
Ford Snow Braker
Feb 8, 2007 01:35 PM
ford_guy_08
Dec 12, 2006 07:18 PM
FordRacing2
15
Aug 12, 2003 09:39 PM
33bronco
1966 - 1977 Early Broncos
Jan 12, 2003 10:48 PM
