wiper control mod.
Old Nov 18, 2004 | 12:43 PM
fordboy9876's Avatar
fordboy9876
Red face wiper control mod.
i can not locate it, alldata states that it is behind the RH side of the instrament panel near the upper cowl. but no luck, do any of you know the location? this is on a 1993 f150 flareside 4x4 MT 302ci, thanks
Old Nov 18, 2004 | 01:07 PM
guzzler96's Avatar
guzzler96
Lightbulb
Is wiper control mod. the same as the Interval Governor that controls the intermitten speed of the wipers?? The Chilton manual that I have says " Reach up under the instrument panel, behind the wiper switch, and locate the governor. Unplug the wiring connector and remove the wiring clip from the panel reinforcement. Remove the governor attaching screw and remove the governor. Installation is the reverse of removal. Its on page 6-38 in chassis electrical for the instructions and page 6-40, FIG. 72, for the diagram. Don't know if we are talking about the same thing??
guzzler96
Old Nov 18, 2004 | 02:33 PM
midlf's Avatar
midlf
The Chilton is out of date for a '93. That refers to the location for the module when the switch was on the dash. The module was moved when they went to the multifunction switch on the column. The Ford manual for '93 says it is on the firewall behind the glove box. I have not gone looking for mine yet, just read about it, so I can't provide practical input. (My wipers won't stop by themselves so the park switch is the most likely culprit. Hopefully I'll be able to get to it this weekend.)
Old Nov 18, 2004 | 02:57 PM
guzzler96's Avatar
guzzler96
I would suggest doing a search then. There have been several post on here lately dealing with that type wipers.
Old Nov 18, 2004 | 07:02 PM
fordboy9876
Thumbs up
it was behind the glove box, thank you all very much
