Sponsored by: Real Truck
2000 f350 abs
Old Nov 18, 2004 | 10:27 AM
clydehauler's Avatar
clydehauler
2000 f350 abs
Hi, I am having problems with a 2000 f350. My abs light came on and my speedo doesn't work below 30 mph. Is there a way to find the codes, if any, yourself or other easy fixes. What is this vss that i have read about? THANKS!!
Old Nov 18, 2004 | 10:31 AM
steamer1234's Avatar
steamer1234
You will find on top of the rear diff. one screw. remove it clean it replace it. If this does not work replace it $25.00. If this does not work do a search here and you will find out more than you want to know.
Old Nov 18, 2004 | 10:42 AM
clydehauler
THANKS!!! I will try it. Does NAPA sellone of those also?
Old Nov 18, 2004 | 12:20 PM
steamer1234
I picked mine up at the Ford Dealer
