Clutch Problems?!
Old Nov 18, 2004 | 09:48 AM
Venom_Fang_16's Avatar
Venom_Fang_16
Exclamation Clutch Problems?!
I own a 95 F150 with a 4.9 and 5 speed. Every time I go to let out on the clutch to change gears or take off the truck lerches noticeably it kinda does a herket jerkey forward backward motion the only way to stop it is to rev a little higher and ease the clutch out slow letting it sli quite a bit before grabbing. I'm relatively inexperienced with transmissions so any help is greatly appreciated.
Michael
Old Nov 29, 2004 | 07:30 AM
guzzler96's Avatar
guzzler96
Lightbulb
You might want to search and/or post in the Clutch, Transmission, Differential forum and see if you find anything on this and maybe get more response??
guzzler96
Old Nov 29, 2004 | 07:49 AM
holland501's Avatar
holland501
First check to be sure the linkage is movng freely. If everything is fine then you have a worn out clutch. Time for a new one. Good luck.
