hi-boy
Old Nov 17, 2004 | 09:10 PM
nobull4x4's Avatar
nobull4x4
hi-boy
im in an argument with a friend of mine about what makes a hi-boy, i think its the 60's front and rear, he says it's just the 3/4ton 4x4 help me please
Old Nov 17, 2004 | 09:42 PM
dots's Avatar
dots
any F250 4x4 from 1967 - 1977 and a half.
although they use the same frame all the way back to 1959 I believe for the F250 4x4. if it came stock with a divorced transfer case its a highboy.
Old Nov 17, 2004 | 09:55 PM
ivanribic's Avatar
ivanribic
Follow this link: https://www.ford-trucks.com/forums/s...78&postcount=8 It's in the FAQ's at the top of this forum . . . everything you need to know about "highboys" is there.
Old Nov 25, 2004 | 10:14 PM
Thomasm67's Avatar
Thomasm67
What makes a Ford Hi-boy is Ford put a Factory 4" Block between the rear axels and the leafs springs lifting it . So it was 4" over a stock ford 4x4. They add heavy duty shocks and i think added extra leaf's on the rear.
Old Nov 25, 2004 | 10:21 PM
FordPickup460's Avatar
FordPickup460
Ford didnt add anything, those blocks were standard on ALL 67-77 1/2 F250 4x4's. Ford didnt name the trucks Highboys either, that was a nickname given to them later on. You wont find a 67-77 F250 4x4 without that blocks unless someone removed them.
Old Nov 25, 2004 | 11:36 PM
whd507's Avatar
whd507
generally the "highboys" have a "divorced" transfer case, and a beam across the framehorns to hold the front of the leaf springs. 77.5 and later had "married" transmission and transfer case.
defiantoutlaw
17
Mar 31, 2013 10:54 PM
mitchell390
Mar 23, 2012 05:25 AM
64 hi-boy
Feb 4, 2010 08:06 AM
64 hi-boy
Feb 3, 2010 08:30 PM
tdmoparguy
Jun 3, 2009 12:08 PM
