Lifting Twin I-Beams
Old Nov 17, 2004 | 08:00 PM
Boss50's Avatar
Boss50
I'm planning on lifting my '81 F100 2wd. I have 2 inch blocks for the rear, and I want something around 1/2-1 inch for the front. Coil spacers would work nicely, but what do I have to do to keep the tires from slanting out more than they already are? Do I need some kind of drop brakets for the radius arms and axles?? and where would I get these? Thanks.
Old Nov 17, 2004 | 08:21 PM
nickmobile67's Avatar
nickmobile67
What's the point in lifting a 2wd truck exactly?
Old Nov 17, 2004 | 08:48 PM
dirtygrunt's Avatar
dirtygrunt
hey I know you want to left it only two inches but you can get a kit from skyjacker for a 4 inch lift I have the six inch lift and it has drop brackets for radius arms and twin I beam brackets. Maybe this helps
Old Nov 17, 2004 | 09:28 PM
ry2krazy's Avatar
ry2krazy
i personally dont think an inch and a half is gonna make that much of a difference. sure radius arms wont be at a factory angle but i would imagine that the camber could still be adjusted fine. seeing as its a two wheel drive the pinion angle isnt gonna matter any. i say go for it.. see what happens. just my two cents
Old Nov 17, 2004 | 11:39 PM
mustange70's Avatar
mustange70
I would get some Progressive rate leveling springs, then take it to a shop that knows the ford front end as they will be able to align it, believe me you will want to have it aligned.
Old Nov 18, 2004 | 12:11 AM
NeoCowboy's Avatar
NeoCowboy
when you say coil spacers your not talking those cheep blocks that spread out one coil of your spring are you? I can't really see the point of lifting 2wd but have fun with it. If you want a good cheep lift and you don't use the truck for hauling do a shackel flip on the rear rather than blocks. There is some info about this on the 4x4 forum. I'd have to talk a look at the front of my friends 2wd in order to make a good suggestion for the front but don't do a lift kit from a store like Azone they are junk
Old Nov 18, 2004 | 11:45 AM
king1884's Avatar
king1884
Jeffs Bronco Graveyard has the 4" suspension lift for the 2wd trucks for $450 plus shipping. Thats what I am gonna do on my 2wd, just because I want to.
Mustangking1
Sep 8, 2013 03:02 PM
mier1
Nov 25, 2010 10:13 AM
AJSXLTSPORT
Jan 24, 2007 11:02 PM
MXZX1100cc
Jan 31, 2005 03:10 PM
DougD
Nov 17, 2004 09:17 PM
