sources for gear ratios
Old Nov 17, 2004 | 02:04 PM
Oval_obsessed's Avatar
Oval_obsessed
Does anyone know of any sources to tell you what the gear ratio could be if you can only see the ring gear? What I 'm getting at is I have a 9" 3rd member that all I can see is the 42 tooth ring gear and can't quite get a good count on the pinion and the tag is gone? 42 tooth gear + ??? === 3.50 ??
