engine swap
Old Nov 17, 2004 | 11:56 AM
jas2187's Avatar
jas2187
engine swap
I have a 80 f-150 with a 302 and a c-6
and i want to put a 351 out of a 81 ltd
will every thing bolt up? what will have to be changed?
thanks jason
Old Nov 17, 2004 | 12:01 PM
RR4E's Avatar
RR4E
351 m or 351 w? You'll have more luck with the 351w. The M block will need a different transmission.
Old Nov 17, 2004 | 12:08 PM
jas2187's Avatar
jas2187
i just heard about the car and im not sure which one it is
what is a easy way to find out the difference?
Old Nov 17, 2004 | 12:32 PM
RR4E's Avatar
RR4E
The w block will be similar sized to your 302. The M block is substantially bigger. If the car is relatively clean, it should be stickered on the air cleaner or valve cover. Worst case, ask the owner.
Old Nov 17, 2004 | 12:39 PM
lmadore's Avatar
lmadore
I don't think they used the 351M in passenger vehicles especially after 1980.
I have seen a 1977 LTD w/ the 351M. Those were big cars though.
Old Nov 17, 2004 | 01:51 PM
ronclark's Avatar
ronclark
Look at where the thermostat housing connects to the motor. On a 351W the thermostat housing connects to the intake. On a 351M the thermostat housing connects to the motor block because no water flows through the intake on a 351M.
Old Nov 18, 2004 | 11:40 AM
jas2187's Avatar
jas2187
it's a 351 w
Old Nov 18, 2004 | 12:10 PM
ronclark's Avatar
ronclark
If its a 351w then the motor will bolt to the trans and engine mounts. Because the 351 is a taller wider block than the 302 then you need the brackets for the alternator power steering AC from the 351 motor.
Old Nov 18, 2004 | 01:20 PM
jas2187's Avatar
jas2187
Will the exhaust have to be altered any to fit the 351?
i had to true dual exhaust on the 302.
And what about would the horsepower difference be the 351 was just rebuilt and has a police intercuptor cam and crank bored .30 over
Old Nov 18, 2004 | 02:11 PM
ronclark's Avatar
ronclark
Don't know for sure about the exhaust, but the 351 is wider at the top where the exhaust manifolds bolt on due to the taller block. If you have X pipes or crossover pipes then they might not be wide enough without alteration.
Old Nov 18, 2004 | 04:55 PM
bremen242's Avatar
bremen242
the exhaust will be probably an inch off... I think the 351 is 2inches wider...
