1983 firing order
Old Nov 17, 2004 | 11:19 AM
melvinjo's Avatar
melvinjo
1983 firing order
Could someone post the firing order and terminal direction of rotor cap, for a 1983 302? My Haynes doesnt seem correct
Old Nov 17, 2004 | 12:44 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Since the way you observe the wires on your distributor conflicts with your Haynes, you may have EEC-III igniton with a Dura Spark III distributor. You can confirm this if your distributor has no vacuum or mechanical advance mechanism on it. Also, there will be nothing inside the distributor except the shaft and rotor. There will be no stator/reluctor as in the Dura Spark II distributor and ignition.
The firing order is the same as (most) all other 302 engines: 1-5-4-2-6-3-7-8
But, the the order the wires are arranged on the distributor cap is: 1-3-4-8-6-5-7-2
This is because the EEC-III distributor has electrodes on both sides of the rotor. It fires alternately from both sides. So even though it's wired in a different order, if you go back and forth from one side to the other, the firing order is the same. The direction is counter-clockwise.
pageparsley
Modular V8 (4.6L, 5.4L)
Jan 4, 2009 09:43 PM
coleaclark
1978 - 1996 Big Bronco
Apr 12, 2008 11:21 AM
krasmussen
Apr 9, 2007 09:38 AM
lephant
Feb 25, 2002 11:27 PM
83bronc
Nov 24, 2000 10:43 AM
