1985 bronco efi 302 fireing order???? - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco
Old 04-11-2008, 11:17 PM
coleaclark coleaclark is offline
coleaclark is starting off with a positive reputation.
what is the firing order???
Old 04-12-2008, 12:21 PM
kenpobuck's Avatar
kenpobuck kenpobuck is offline
kenpobuck is gaining momentum as a positive member of FTE.kenpobuck is gaining momentum as a positive member of FTE.
As long as it isn't a H.O. motor, it is the same as all other 302's, 1-5-4-2-6-3-7-8. The rotation is counterclockwise.
1968 ford f-600 cylinder and firing order kgh Large Truck 2 04-02-2012 12:01 AM
1987 F-150 300 firing order cyn 1987 - 1996 F150 & Larger F-Series Trucks 3 07-03-2006 12:55 PM
7.3 firing order homer4111 1999 - 2003 7.3L Power Stroke Diesel 5 05-05-2004 11:29 AM
Firing order? carpe_diem Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 9 08-01-2003 10:22 AM
85 BRONCO ll / FIRING ORDER 83bronc 1978 - 1996 Big Bronco 4 11-24-2000 11:43 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
