I don't know for certain, but I'd bet that it is. Another option is one of these, once they get them back in stock. That's the unit I bought, and it works great. It's designed for continuous use, rather than some that are designed for occasional use only. Should last a long time.
Does any one know if the International Glow plug relay is the same as Fords?
Working on a 97 F250 7.3
Yes it is - if you pull your old one out you'll even see an "International-style" part number on it (I think it was stamped into the metal mounting plate.)
Last GPR I got for my '97 came from the International dealer - they're way cheaper!
a better deal on motorcraft glow plugs is O'Reilly's....they run about 8.50$ a piece for the Motorcraft/Beru. that coems to what, under 80? whats the camp sensor? been seeing it but no explenation...
CAMPS/CPS = camshaft position sensor. Ford and IH use different terminology.
