Few newbie turbo questions?
Old 11-17-2004, 12:22 AM
CampoRoofSuperD's Avatar
CampoRoofSuperD
CampoRoofSuperD is offline
Whats up guys,
Im new to FTE, I currently drive a 2000 powerstroke extended cab f250 for work. I am working on selling my 2000 BMW coupe, which is my daily driver, to make room for a new '05 Crew Cab, and im pretty sure with the powerstroke.
Im graduating school, and the BMW just isnt going to be practical, i need to be able to haul things for work...Im in construction currently and am graduating with a degree in Construction Managment
I have a few questions. Sorry if they sound dumb. Im used to working with turbo's on little rice burners.
Anyway here goes...
1.) are there intercooler kits for the SD
2.) Is there a need for a turbo timer
3.) Is there any function for a blow off valve on a diesel
I think that is it... Im sure ill have more questions down the road...
I hope to take delievery on a '05 before the first of the year.....
thanks
Kevin
Old 11-17-2004, 06:40 AM
SBV45's Avatar
SBV45
SBV45 is offline
Kevin, go to the tech folder above and read through the section on the turbo in the 6.0L Bible.
1. The Ford SD with a 6.0 comes with an intercooler between the turbo and intake.
2. Not unless you are going to do some heavy hauling.
3. Not on this 6.0. The turbo is electronically controlled variable geometry.
Old 11-17-2004, 11:17 AM
CampoRoofSuperD
Thanks for the info... Ill defently look into that tech thread....
when you say heavy haulin what are we talking about???
would a 35 foot baja tri axle boat trailer be heavy enough??? Or a dump trailer with 9,000 lbs of shingle tear off?
thanks
Kevin
Old 11-17-2004, 05:07 PM
SBV45's Avatar
SBV45
SBV45 is offline
thanks
Kevin
That would qualify!
Old 11-17-2004, 07:44 PM
CampoRoofSuperD
most definatly.....
thanks for the info
kevin
