Octane Question
Old Nov 22, 2004 | 05:35 PM
GST97's Avatar
GST97
I am glad that I have never even had to hear this pinging people refer to
My truck runs just fine on 87, however, some gas companies, like BP/Amoco add detergents to their 89+ gas to help keep the fuel system clean.
I am also glad that I can run 87 on the truck, as my car requires premium... and with the horrid gas mileage the truck gets, using premium every time would bankrupt me.
But on the car, I still get over 20 MPG and it sees a lot of WOT use at 21PSI of boost, so I can live with paying for premium
-Chris
Old Nov 22, 2004 | 08:16 PM
Popa Tim's Avatar
Popa Tim
What does ping sound like????
Could Someone post a link to a .wav or mp3 please.
Thanks in advance.
Popa Tim
Old Nov 22, 2004 | 10:35 PM
t_dickie's Avatar
t_dickie
I don't think that there would any real advantage to using premium. It will probly get you a bit better mileage, but be offset by the increase in price. I'd use the lowest rating that doesn't make it ping.
Trevor
Old Nov 23, 2004 | 04:21 PM
qman's Avatar
qman
Hey FordPerf300, higher octane gas isn't harder to burn. Its more resistant to pre-igniting in a hot combusion chamber (that's what pinging is). Higher octane gas burns just fine once the spark is applied. You also don't get better performance. All you get is less likely to ping. That's it.
And Poppa Tim, I don't have a sound bite for you but pinging sounds kinda like something is rattling around inside your engine. Kind of like someone threw a handful of broken porcelain in there. I had an old Volvo that required 87 octane gas. If I used 85, which would happen whenever I lent to car to someone, it would ping when I would gun the accelerator from a dead stop until the car got some speed going. The ping would go away if I backed off on the accelerator. I don't know why its called pinging cause it doesn't sound like a ping. It just sounds like something is rattling around in the engine.
Old Nov 23, 2004 | 04:48 PM
Popa Tim's Avatar
Popa Tim
Thanks qman. I think I've heard that before and thought it was a timing chain rattling or something.
Old Nov 23, 2004 | 09:44 PM
SoCalDesertRider's Avatar
SoCalDesertRider
It does sound a bit like a chain being waggled around... kinda like a diesel engine.
Old Nov 29, 2004 | 04:40 PM
qman's Avatar
qman
It just hit me. The sound of pinging is the same sound that a diesel makes. But in a gas engine its just not as loud. This came to me because I remembered that a diesel doesn't have spark plugs. I think that in a diesel engine the compression of the fuel/air mixture ignites the stuff. So what you have in a diesel engine is constant pinging.
Old Nov 29, 2004 | 05:41 PM
Chris_ce's Avatar
Chris_ce
Yes but a diesel only has one souce of ignition. Where the problem is with gas is that the heat and comp. light the fuel and the spark plug then the two flame fronts hit each other causing engine damage. That and if it explodes to soon while the piston is in the upward movement it causes damage.
Old Nov 29, 2004 | 10:39 PM
rlh's Avatar
rlh
I have a 3.2 V6 rated at 205 HP that sometimes rattles when we run 87 in it. Therefore, we run 93 in it and it doesn't rattle. In reallity, a computer "flash" would probably program it to run right on 87. We certainly wouldn't run it otherwise.
In my Bronco and F350, I only run high octane when towing due to lesser heat build up.
projectdagger
Mar 3, 2007 02:45 PM
Rxman
2004 - 2008 F150
22
Jul 13, 2006 09:32 AM
tabanks412
2004 - 2008 F150
16
Mar 6, 2005 12:54 AM
Geoboy
Modular V10 (6.8l)
20
Jan 21, 2004 09:32 PM
grizz5675
Modular V8 (4.6L, 5.4L)
Jan 8, 2004 01:41 AM
