Lowering the rear end?
Old Nov 17, 2004 | 03:31 PM
WhiteNight's Avatar
WhiteNight
Industrialjunk,which brand did you go with any did they offer more than one position?
Old Nov 17, 2004 | 03:45 PM
industrialjunk's Avatar
industrialjunk
Western chassis is who makes them. I got them from a Cooper tire store a friend of mine owns $45.00
It took me about 20 minutes to install them. They come with two diferent positions 1" and 2" lower.
Old Nov 17, 2004 | 04:54 PM
SCREW-ON-24s's Avatar
SCREW-ON-24s
Here are links to the pics...I don't think we are supposed to post pics in the threads (are we?)
Before
http://images.andale.com/f2/108/130/...3_DSC00406.JPG
After
http://images.andale.com/f2/108/130/...5_DSC00409.JPG
Like I said I went with DJM shackles. I got them from Stylin Concepts and they cost a little under $60 shipped. It should take about 30-45min to put them on. One suggestion...don't over tighten the bolts or they will squeak.
Old Nov 17, 2004 | 05:40 PM
kabcpapc's Avatar
kabcpapc
Originally Posted by Mystery Fan
I'm planning on purchasing a pair of new shackles to lower my Supercab 2" in the rear. Shackles run $40-$60 a pair. They aren't that hard to change.
I'm looking for a good deal on a rear anti-sway bar to add also.
My son just bought a hellwig sway bar for his lowered (2" front; 4" rear) 1997 F150. It wouldn't fit properly because the sway bar links are too long. Hellwig says not to cut or modify any of their components. Better check it out before you order the lowering kit or sway bar.
Old Nov 17, 2004 | 06:46 PM
Oneagle1's Avatar
Oneagle1
I put the Beltech 2" lowering shacles on. I tow a bass boat and a 22' travel trailer with no problems. Makes for a nice mod
Old Nov 22, 2004 | 06:03 PM
flyboy5111's Avatar
flyboy5111
Use U-bolts from the front end of a 2000 4x4 v-10 Excursion, they are the same diameter so you can re-use the nuts. They should cost about $25-$30.
Old Nov 23, 2004 | 02:42 AM
82F1507.5's Avatar
82F1507.5
Lowering the SCREW
SCREW-ON-24s
Thanks for the pictures, really helped me make up my mind. I'm goin4it!
Old Nov 23, 2004 | 04:58 AM
LOWERED_F250's Avatar
LOWERED_F250
Has anyone use the 2" groundforce lowering shackles? I am about to put them on mine.
azviking
Oct 18, 2005 10:02 AM
UNLOADIT
2004 - 2008 F150
Sep 22, 2005 01:06 AM
UNLOADIT
2004 - 2008 F150
Nov 17, 2004 01:25 PM
UNLOADIT
2004 - 2008 F150
24
Nov 15, 2004 05:41 PM
UNLOADIT
2004 - 2008 F150
Nov 15, 2004 12:30 AM
