1978 - 1996 Big Bronco
Horn relay location?
Old Nov 16, 2004 | 06:51 PM
rbrewrr's Avatar
rbrewrr
Ok, I haven't had much luck locating this one: A couple months ago, my Bronco's horn got stuck on. My Chilton's and Haynes manuals aren't really that helpful in locating where the relay is (I'm only assuming there is one at this point.) So I just pulled the fuse for the horn/cruise control.
It's an 87 Bronco - EB w/5.8L. Naturally, it's got all the options. Let me know if I need to provide more information.
Thanks,
Rob
Old Nov 16, 2004 | 09:01 PM
Joboo's Avatar
Joboo
Not sure if this will help you but mine, (90), is located behind and to the right of the glove box. Its about 2 or 3 inches past the outside edge of the box and directly under the far passenger side ac vent.
Hope it helps.
Old Nov 17, 2004 | 12:33 AM
rbrewrr's Avatar
rbrewrr
Thanks, I'll check it out this weekend.
Thanks for the tip.
