Sponsored by: Auxito
Decrease in Gas mileage '00 f150 4X2
Old Nov 16, 2004 | 05:44 PM
gatorf150's Avatar
gatorf150
I have had my truck for almost a year and a half. It is a '00 f150 4X2 with the 5.4 V8. During the 15000 miles I put on it I was getting 16-17 mpg on the highway and 15 with mix city/highway. These last few months however my mileage has just been getting worse and worse. I am at about 13.5 during a recent highway trip going 75 mph. I replaced the air filter and the tire pressure is good. The replacing of the air filter did not seem to have any effect. I called ford and they suggested an 80$ diagnostic which may not show anything. The ride feels smooth and I have not noticed any other problems just a decrease in mpg. I baby the truck to milk the best mpg so this is very frustrating. Does anyone have any suggestions. Jiffy lube keeps pestering me to change the fuel filter since I hit 43000 miles. Any ideas would be greatly appreciated as I would prefer to keep it out of the dealership since they rip you off. Thanks guys
Scott
Old Nov 16, 2004 | 08:31 PM
Racerguy's Avatar
Racerguy
Has the MAF sensor ever been cleaned? It's easy to do and sometimes helps.
Something is overlooked quite often is the thermostat. If the engine doesn't get up to normal operating temperature it can hurt the gas mileage quite a bit. The best way to check for that is to hook up a scan tool and watch the coolant temperature on that.
Lots of scan tools don't have that capability but the ones your dealer uses do.
Old Nov 17, 2004 | 03:20 AM
wgotthardt's Avatar
wgotthardt
Originally Posted by gatorf150
I Does anyone have any suggestions. Jiffy lube keeps pestering me to change the fuel filter since I hit 43000 miles. Any ideas would be greatly appreciated as I would prefer to keep it out of the dealership since they rip you off. Thanks guys
Scott
Scott,
I also own a '00 F-150, when I bought the truck this past summer I was only getting 12-13 mpg over my first five fill-ups. I decided to change the fuel filter with info I found here, and now average between 15-16 mpg. The fuel filter change is an easy DIY job, you'll need just one special (line disconnect) tool (I used the cheap 5/16" plastic one, and it worked just fine).
Here's a helpful thread...
https://www.ford-trucks.com/forums/s...d.php?t=267239
Cheers, Wm.
Old Nov 17, 2004 | 04:32 PM
gatorf150's Avatar
gatorf150
thanks for the tips guys I will check both of them out and see if it helps matters. I appreciate the quick responses!! If you have any other ideas go ahead and post but I work on next week when I get some free time.
Scott
bulletpruf
37
Sep 15, 2012 09:13 AM
timbuktu78
Feb 23, 2011 11:24 PM
CobraGT40
Oct 31, 2009 11:55 PM
ATCman
1997 - 2003 F150
20
Sep 29, 2003 02:16 AM
GSMcDermid
Mar 19, 2002 02:51 PM
