Electrical problem
I'm new here and a just bought a 71 F100 last week. I was wondering if anyone could help me out with the following?
The electrical system has been hacked up over the years and the brake lights/tail lights/blinkers are the big issue. Right now the turn signals are working, lighting up the inner filament. The running lights are working, lighting up the other filament. Only one brake light is working lighting up the same filament as the blinker, is this right? When I got the truck the brake lights didn't work at all and if you put on the right blinker nothing happened, left blinker made both sides blink! So I've made headway but I'm not sure if I have it wired correctly so far.
Bulbs have been checked and swapped.
By the way, great website!
Thanks
Rob
EDIT: I should add, look for and remove, any and all crimp style connecters, and replace with solder and shrink tube to avoid possible bad connections. Crimp style connecters work fine for an "it'll get you home" fix, but have a habit of loosening inside to where they look like they're connected, but really are not.
The brake switch definitly works, but that is all hacked up too, so I don't know if they got it hooked up to the correct wires afterwards.
I odered a factory manual from Motorhaven with a wiring harness diagram, so hopefully that will help.
Thanks for all advice!
Rob
