Sponsored by: Real Truck
bump stops
Old Nov 16, 2004 | 03:19 PM
genemurphy's Avatar
genemurphy
bump stops
I have just purchased a 2004 350 power stroke with off road suspension package. I am hearing a bumping noise when I make a sharp turn, lock to lock. The dealer says this is normal and I am just hitting up against the bump stops.
Is this normal? Can it be eliminated?
Thanks to all respondents.
Old Nov 16, 2004 | 04:16 PM
cwb's Avatar
cwb
Uhh unless you drive like Junior in the city you're not hitting the bump stops. You might be hitting the steering stops but that's doubtful. Usually you only hit them when you make a u turn and then they don't really go "bump" Maybe you have tires rubbing on the springs?
Old Nov 16, 2004 | 05:38 PM
Pikachu's Avatar
Pikachu
If you're turning the wheel lock-to-lock, you are hitting the steering stops. I can hear mine hit if I turn the wheel fast enough.
EpicCowlick
Oct 27, 2019 08:27 PM
snoopt1
Jul 2, 2011 01:50 AM
54deuce
Feb 18, 2010 05:20 PM
TayzGpa
Jul 4, 2007 02:39 PM
