01 hates cold mornings
Old Nov 16, 2004 | 09:59 AM
c08win's Avatar
c08win
my 2001 exployer just will not stay idling in morning below 45. my wife needs to keep the idle up high til her boy gets warm, then it run great the rest of the day.had this problem last year, but run out of cold morning. i've changed plugs-wires, iac,pcv,tps,egr. maybe it needs to be put in the garage, rapped in a blanket. any suggestion?
Old Nov 16, 2004 | 10:36 AM
Gil Chesterton's Avatar
Gil Chesterton
Hello,
I had (have) a similar problem with my 91 EXP and it seems to be the IAC. Check other posts on FTE and you'll see a common theme with the IAC. I actually have two IAC units that I clean and rotate every Spring/Fall. It may sound ridiculous but after enduring the same issue over and over it seems to work for me.
There is a thread on cleaning the IAC in the FTE somewhere or it may be at http://www.glue.umd.edu/~singletn/exp.html
Good luck,
Gil
Old Nov 16, 2004 | 01:20 PM
87 XLT's Avatar
87 XLT
Might be a bad engine coolant temp sensor. Have you pulled any trouble codes?
Old Nov 16, 2004 | 02:02 PM
mukat's Avatar
mukat
I have a 2001 Explorer Sport with the same problem and I also had the IAC replaced last year. Guess what, as soon as the weather cooled down it started happening again. I don't know if this is correct but there is(?) a service bulletin or whatever they call it which advises the Ford dealers to change the faulty MAF sensor gasket, disconnect the battery and reset the computer. As I said I don't know if this will solve anything at all. Maybe someone else can clear this up for you and me.
Terry
Old Nov 16, 2004 | 02:28 PM
mukat's Avatar
mukat
Sorry, I forgot to mention that I also have the "door ajar" problem. Tried WD-40 last night and opened and closed the doors and rear hatch until my neighbor came out to see what the hell was going on. Will try again tonight.
Old Nov 16, 2004 | 06:44 PM
bulldog3531's Avatar
bulldog3531
I have a 98 Explorer Sport with the same problem. I have changed the iac, egr, tps, plugs, and wires. It still has the same problem. I have read somewhere or was told that it could be the fuel pressure regulator. I don't know if it is true, for one I don't know where it is.
Old Nov 16, 2004 | 07:54 PM
c08win's Avatar
c08win
i did pull codes last winter, an came back as oxygen sensor,s. i changed both. they said without engine lite on, thy can not pull any codes. i put the old iac valve on tonite seeing if the may have sold me a faulty iac.
Old Nov 16, 2004 | 08:52 PM
Racerguy's Avatar
Racerguy
A common problem on a 4.0 SOHC is bad intake manifold O-rings. When they are bad they cause a vacuum leak which can lead to stalling, rough idle, O2 codes etc. The problem is usually worst when the engine is cold.
Old Nov 16, 2004 | 11:02 PM
98xlt's Avatar
98xlt
my 98xlt (4.0 sohc) ran bad on cold weather startups. the recall m12 fix solved my problems. I'll verify the recall number again tomorrow, I'm going from memory. two years later I needed to change out the IAC for idle problems in WARM weather.
Old Nov 17, 2004 | 12:29 AM
Racerguy's Avatar
Racerguy
https://www.ford-trucks.com/forums/a...ex.php/t-31352
Old Nov 17, 2004 | 10:01 AM
mukat's Avatar
mukat
Thanks guys! The WD-40 did work. I didn't have to spray a second time, I just opened and closed the door a couple of times and the lights went out.
Btw, I also have that rattle in the morning. I was told it was the timing belt but the reason for it was that either the gasket for the MAF sensor was leaking or the O2 sensors needed to be replace and the computer takes it's time decided how the car is going to run. That's why the sound goes away eventually.
Oh yeah, my wife called me this morning and said the "service engine light" came on. Sounds like last year. My mechanic couldn't quite figure out the codes and said it looks like both O2 sensors. When I spoke to a Ford mechanic he said it's highly unusual that both would go at the same time.
Old Nov 17, 2004 | 07:27 PM
Racerguy's Avatar
Racerguy
Take a look at the link in the post a couple posts above this one. Owner Notification Program 00M12 pretty much covers your problems.
Old Dec 4, 2004 | 11:14 AM
c08win's Avatar
c08win
changed IAC again, still the same problem. codes read 1504.300,301 any suggestions?
Old Dec 5, 2004 | 05:35 AM
gggddd555's Avatar
gggddd555
Intake manifold orings fixed this problem on my 99 Mountaineer. The orings are part of the 00M12 kit listed above.
Old Dec 6, 2004 | 02:00 PM
c08win's Avatar
c08win
did you change the o-rings yourself? an is it a difficult job to do myself?
