Power Steering:
Old Nov 16, 2004 | 09:33 AM
blockheadbob's Avatar
blockheadbob
Power Steering:
Im new to this forum and I have a question. Is there any way to put power steering on a 72 F250 without replacing the front axle?
Thanks,
Bob
Old Nov 16, 2004 | 11:42 AM
champdog's Avatar
champdog
power change out
I put power stearing on my 68 f-150 2*4 i took a Bendix stile gear box. I got my pump and parts from a junk yard and got new hoses from a Kragens. I had to make a costom mounting bracket for the pump but it was easy.I also nead to shorten the stearing collem.If you can weld you can do it your self. Im not shure if a 250 will take the diferent stile of gear box there are two more stiles of gear boxes but if i used them i would half to modify the frame on my 150 250?? might not half to. I did not half to change anything on the axiles.
Old Nov 16, 2004 | 12:10 PM
4Cammer72's Avatar
4Cammer72
power steering columns are shorter than the manual. most parts are available from junk yards. i got my set up for 50 bucks. it's pretty straight forward. good luck.
Old Nov 16, 2004 | 12:44 PM
heep70's Avatar
heep70
Thanks,
Bob
I did it this way, works great. Cost me like $300 all together.
https://www.ford-trucks.com/article/...r_Highboy.html
Old Nov 18, 2004 | 03:40 PM
JDenver's Avatar
JDenver
Steerin
If you can find a pre-78 f-250 with power all of the parts should swap out. You can keep your original column but will have to slide the shorter power shaft into it. This changes the angle of the column coming out of the firewall a little but seems to work ok.
You will also need to replace the drivers side engine tower to one from the truck with power steering (must be the same engine family) if you are using a ford steering box. There is another set of holes already in the frame that will mount the new tower.
It helps to get a truck with the same engine to eliminate running around looking for the engine tower and the pump bracket. The 250 are still pretty easy to find, a lot easier than the 150 where I am at.
Old Nov 24, 2004 | 10:53 PM
wvmiller68's Avatar
wvmiller68
i replaced my steering box and colum on my 68 added pump took about half a day
Corkwheats
WTB - Parts & other
Jan 4, 2013 11:14 PM
F100steve
Jan 28, 2008 11:39 PM
Bob Crain
May 19, 2005 04:59 PM
