Exhaust Change
Old Nov 16, 2004 | 09:26 AM
99 Six Speed's Avatar
99 Six Speed
Question Exhaust Change
I am thinking about replacing my original exhaust soon . What I am wondering is what brand to go to ? Does anyone have any input on fit , ease of installation , warranty and cost ? Truck has had nothing done to it but am thinking of installing a multiple channel tuner also. Thanks for any help!
Old Nov 16, 2004 | 10:11 AM
mech2161's Avatar
mech2161
Exhaust change is fine, I don't suggest any chip or tuner without gauges. You could cause serious damage if you decide otherwise. Shop around for your exhaust you will find as many systems as you do preferances.
Old Nov 17, 2004 | 08:33 AM
mueckster's Avatar
mueckster
I have the MBRP 4" 409 SS exhaust system. Came with a 5" double wall tip. The fit is excellent and sounds good, too. The main reason I put the exhaust on is to reduce EGT's. Could not keep my foot in it without the temp going to 1400 and above. Problem solved. Did not notice much if any loss of bottom end power with the 4" downpipe. Turbo spools up quicker and acceleration is awsome when passing in overdrive.
