Maintenance codes
Old Apr 15, 2002 | 02:16 PM
Hank85713's Avatar
Hank85713
Maintenance codes
Anyone tell me where I can find the code repair info? I get a 543, which is a 2dery fuel pump circuit fault. But I do not have any way to follow up on this like what is involved in toubleshooting from that point on. My haynes/chilton doesn't coveer teh various codes.
TIA Hank
Old Apr 15, 2002 | 09:14 PM
Ken00's Avatar
Ken00
Maintenance codes
I have the 88 book, not sure what year you have. Does the pump run for a few seconds when you turn the key? Have you checked the inertia switch? The relay? What problems are you having?
Old Apr 15, 2002 | 09:51 PM
Hank85713's Avatar
Hank85713
Maintenance codes
Ken, I ve got what appears to be a common problem on a 94 4.0. Starts and then stumbles will not accell and dies. Let it sit for a while and it will start right up like nothing happened. Yesterday I had to be towed home and it sat for about 2-3 hours then started. Today no probs. Just picked up a fuel pressure gauge from sears will check it tomorrow. Only code I have is the one described above.
Thanks Hank
Old Apr 16, 2002 | 10:18 AM
Ken00's Avatar
Ken00
Maintenance codes
Hank,
I'm not familar with the problem but let me know how the pressure is and I would be glad to give you any information my 1988 or 2000 manuals have.
Ken
Old Apr 16, 2002 | 09:46 PM
Hank85713's Avatar
Hank85713
Maintenance codes
Ken checked the fuel pump and it is OK about 38 psi koeo, 32 koer.
Did pick up a bad o2 sensor reading (lean) so that may explain the intermittent check engine light ive been getting. Didn't get anything on the 2dery fuel pump circuit this time!
Guess i get to buy 2 sensors this weekend for install.
One strange engine running was that it beeped about 8 times and there ain't no code for that, so I dont know whats happening there.
Where did ya find the codes and how to check them out? I got the ones from ya on the RABS and they worked good. Do ya got the rest scanned also?:P
Thanks Again Hank
Old Apr 17, 2002 | 02:07 PM
Ken00's Avatar
Ken00
Maintenance codes
Hank,
The KOER pressure might be a little low, I don't have my book with me to check. I do have the pinpoint tests in my 88 Ford manual, the manual has everything, and I have another source too. If you would like the tests email me and I will scan them if I doon't have them done. There are other causes for lean codes other than a bad O2.
Ken
Old Apr 18, 2002 | 11:05 AM
Hank85713's Avatar
Hank85713
Maintenance codes
Ken sent ya a mail last night, confirmed after drive home from work 176, 543 KOEO, and a 51/53 lean sensor (I think) engine run.
Will pressure regulator have anything to do with the 543?
thanks Hank
Old Apr 18, 2002 | 12:25 PM
Ken00's Avatar
Ken00
Maintenance codes
Hank,
I sent you an email back at 9:40am est 4/18, did you get it.
Ken
Old Apr 18, 2002 | 02:06 PM
Hank85713's Avatar
Hank85713
Maintenance codes
will let ya know when I get home at work now.
Thanks
Old Apr 18, 2002 | 02:31 PM
aksniper's Avatar
aksniper
Maintenance codes
lenny1carl
Jul 13, 2007 06:57 PM
hank farmer
2004 - 2008 F150
Oct 18, 2006 02:01 PM
ChurchTurtle
18
Jul 5, 2005 09:25 AM
Henry.aka.hank
Jan 27, 2005 04:58 PM
